Hello everyone,
I am new here and I am building a delta with Repetier v0.91 on an Arduino Mega.
The Movement works well, but when I want to home the axes, the endeffector wants to aproach the following coordinates:
X:2,36
Y:181043,4
Z:295
At least Z makes a little bit of sense, because 295 is my top height
But the home position is in reality 80mm under the endstop trigger position, so it should be 215
And the other values seem to be completely random and I cant find a clue in the config file.
They are always the same values btw.
At the moment i force it with
G28 X0 Y0 Z215 to home in a normal position but then it still thinks to be at the random coordinates and i cant move it any longer.
Also the G92 doesn´t change it´s mind about the current position...
Would be great if someone has an idea
