Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 03, 2015 03:05PM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 03, 2015 03:08PM |
dougal1957
OO DURKE OO
ok I did that and entered m119 what am I looking for here? Z is now all the way down on the endstop X and Y are not.
the results should be something like
X_min:H x_min:L y_min:L
or such like
Is your Z now close to bed?
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 03, 2015 03:12PM |
OO DURKE OO
dougal1957
OO DURKE OO
or such like
I am seeing X_min:L y_min:H z_min:L
seem correct? And I am able to manually get it close to the bed with the up down buttons but when I hit the home button it keeps trying to go past the O point where the end stop is. So I had to run the emergency stop command.
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 03, 2015 03:13PM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 03, 2015 03:17PM |
dougal1957
OO DURKE OO
dougal1957
OO DURKE OO
or such like
um that means that you will have to find a way of adjusting that Z Endstop. With the nozzle practicaly on the bed how far off is the endstop and could you get to it by levelling the bed a little lower?
are the X and Y both moving in either direction and can you get them to stop if you activate the endstop manually whilst the axis is moving towards the endstop?
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 03, 2015 03:18PM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 03, 2015 03:20PM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 03, 2015 03:27PM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 03, 2015 03:28PM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 03, 2015 03:29PM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 03, 2015 03:30PM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 03, 2015 03:34PM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 03, 2015 03:57PM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 03, 2015 04:22PM |
OO DURKE OO
Does this have any bearing on the matter? I notice there are no figures for Z.
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 03, 2015 04:24PM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 03, 2015 04:26PM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 03, 2015 06:51PM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 03, 2015 07:08PM |
elwood127
I glued 2 pieces of 1/4" by 1/2" .080 (I think ) plastic to the bottom of my motor mount to close the gap at the z endstop switch. Got me close enough to adjust bed hieght properly. When I added glass to bed I removed one piece.I also had to mount the y axis endstop at the back not the front to get that working right. Search "Bad Printed Parts" here to see how I got around binding of feed screws and rods. Good luck
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 04, 2015 02:01AM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 04, 2015 10:23AM |
dougal1957
Robert
the motherboard as you call it has marking's on it for the endstop positions they all need to be in the sockets marked up as X- Y- and Z- make sure they are in the correct socket for the endstop in question ie your Z endstop needs to be in the Z- socket and so on.
Elwoods idea of putting a shim under the X axis carriage so it contacts the Limit switch is not a bad one your other option is to take the switch of the frame and elongate its mounting holes re-attach it then you should be able to move it up or down to get it in the right place.
we will crack this!
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 04, 2015 10:30AM |
OO DURKE OO
dougal1957
Robert
we will crack this!
How does shimming my endstops help? My end stops are reaching everything fine as of right now. they all tick and can be hit. The only issue is that the Z axis isn't stopping when hit, and the Y axis for the bed sometimes takes a second to figure out it was hit. but they are all positioned well.
I have swapped out my end stops for Y and Z. I have to step out for a bit but I will test it a bit later. The new configuration file is uploaded just not tested as of yet.
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 04, 2015 02:21PM |
dougal1957
Robert
we will crack this!
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 04, 2015 02:23PM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 04, 2015 03:19PM |
OO DURKE OO
anyone have any goog guides for using repetier to print? I need to know how to properly scale an item so it fits my print bed now. Also does repetier have a bed leveling program?
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 04, 2015 03:22PM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 04, 2015 03:25PM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 04, 2015 03:32PM |
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 04, 2015 03:35PM |
OO DURKE OO
The only other thing is I noticed my X axis does not go all the way to the right. It is still missing about an inch to an 1.5 inches on the bar. the extruder comes within about .5 inches of the edge of my print bed do you think that will be an issue?
Re: NEW to reprap and I have an aurora Prusa Reprap i3 QUESTIONS!!!! February 04, 2015 03:36PM |
