Dear all,
I have an Anet A8 Clone with Skynet V2.0 Firmware and installed LJ12A3-4-Z/BX NPN Sensor by using voltage regulator with 100K and 150 K Resistor.
Starting with leveling the z-offset by preheated bed.
What I didn’t understand is why I got different z-offset distances when homing (without any changes in the system). E.G. Once is start homing and level the bed by using Cura and Command M114 I got e.g -0.7 as needed offset. After saving this value to memory I push x-homing function again and start leveling to check the offset distance. I got other offset distance than before. It is very seldom that the value of distance between triggered sensor and bed remain the same. In case of having wrong offset values I will get bed crashes….
Any ideas what could be the issue? Is this an issue with the sensor or mechanic of the printer?
Cheers,
AGRV
