I am in the process of designing my own driver pcb and I am going to use the A4982/A4984 chips in the TSSOP24 package because...
1. It can dissipate more power
2. It is easier to hand solder than QFN
3. It has full protection including short protection
It seems that the Gen6 software is driving all the steppers in 1/8 mode. Is this correct ?
Is there any reason to allow the steps to be changed from 1, 1/2, 1/4, 1/8 or 1/16 steps (A4982 cannot do 1/8 and A4984 cannot do 1/16) ?
If so, by links or by software ?
Is there any requirement to use other than Automatic Mixed Decay mode ?
Does anyone consider it to be an advantage to have a few preselected current limits set by jumper instead of a potentiometer ?
Would 0.5A, 0.75A, 1A, 1.25A, 1.5A, 1.75A, 2A be sufficient ?
Would a user soldered resistor to select be preferable ?
I note that only /ENABLE, DIR & STEP are provided to the driver boards. Has anyone wanted /RESET (or /SLEEP) ?
Could /RESET be common to all drivers ?
