Starting a Prusa Mendel build September 15, 2011 12:32PM |
- Prusa Mendel Frame * Plastic Parts: Sourced from my brother who is printing the Prusa Mendel parts from the CupCake-sized plates. * Vitamins: Sourced from UltiMachine * Belts: Sourced from UltiMachine * Heated Build Plate: Sourced from UltiMachine * 4x Stepper Motor: NEMA 17 Sourced from UltiMachine * Bushings: two options... + My brother is printing some of the new bushings that can hold felt, i would need to glue them on the standard prusa parts...will that work? + I can also order some PLA bushings from ebay - Extruder * Plastic Parts: Sourced from my brother who is printing Greg's Hinged Accessible Extruder + I modified the holes to fit the MakerGear hot end mount according to the comment by "hbs" on the thingiverse page * Vitamins: Sourced from MakerGear (Wade Hardware Kit) * Hot End: Sourced from MakerGear + 0.35mm nozzle + Fully assembled + Wade wooden mounting plate * Stepper Motor: NEMA 17 Sourced from UltiMachine * Hobbed Bolt: Sourced from ebay user :RTQ:US:1123" target="_blank" rel="nofollow">dude_146 - Electronics * RAMPS Fully Assembled w/Arduino Mega: Sourced from UltiMachine - Power Supply * I'm sure i have an ATX power supply somewhere around here...
Re: Starting a Prusa Mendel build September 15, 2011 12:52PM |
Re: Starting a Prusa Mendel build September 16, 2011 07:44PM |
The exported file is saved as D:\3dPrinting\gregsHingedAccessibleExtruder\small_gear_export.gcode It took 31 seconds to export the file. 0 mm of filament used in this print
Re: Starting a Prusa Mendel build September 16, 2011 08:25PM |
(<alteration> ) (**** beginning of start.txt ****) (This file is for a MakerBot Thing-O-Matic) (**** begin initilization commands ****) G21 (set units to mm) G90 (set positioning to absolute) M108 S255 (set extruder speed to maximum) M103 (Make sure extruder is off) M104 S225 T0 (set extruder temperature) M109 S110 T0 (set heated-build-platform temperature) (**** end initilization commands ****) (**** begin homing ****) G162 Z F500 (home Z axis maximum) G161 X Y F2500 (home XY axes minimum) G92 Z80 ( ---=== Set Z axis maximum ===--- ) G92 X-57.5 Y-57 (set zero for X and Y) (**** end homing ****) (**** begin pre-wipe commands ****) G1 X52.0 Y-57.0 Z10.0 F3300.0 (move to waiting position) M6 T0 (wait for toolhead parts, nozzle, HBP, etc., to reach temperature) M101 (Extruder on, forward) G04 P5000 (Wait t/1000 seconds) M103 (Extruder off) (**** end pre-wipe commands ****) (**** end of start.txt ****) (</alteration> ) (<creation> skeinforge </creation> ) (<version> 11.02.23 </version> ) (<extruderInitialization> ) (<craftTypeName> extrusion </craftTypeName> ) M105 (<bridgeWidthMultiplier> 1.0 </bridgeWidthMultiplier> ) (<decimalPlacesCarried> 3 </decimalPlacesCarried> ) (<infillWidth> 0.6 </infillWidth> ) (<layerThickness> 0.4 </layerThickness> ) (<threadSequenceString> loops perimeter infill </threadSequenceString> ) (<operatingFeedRatePerSecond> 32.0 </operatingFeedRatePerSecond> ) (<operatingFlowRate> 255.0 </operatingFlowRate> ) (<orbitalFeedRatePerSecond> 16.0 </orbitalFeedRatePerSecond> ) (<travelFeedRatePerSecond> 32.0 </travelFeedRatePerSecond> ) (<coolingRate> 3.0 </coolingRate> ) (<heatingRate> 10.0 </heatingRate> ) (<baseTemperature> 225.0 </baseTemperature> ) (<interfaceTemperature> 225.0 </interfaceTemperature> ) (<objectFirstLayerInfillTemperature> 225.0 </objectFirstLayerInfillTemperature> ) (<objectFirstLayerPerimeterTemperature> 225.0 </objectFirstLayerPerimeterTemperature> ) (<objectNextLayersTemperature> 225.0 </objectNextLayersTemperature> ) (<supportLayersTemperature> 225.0 </supportLayersTemperature> ) (<supportedLayersTemperature> 225.0 </supportedLayersTemperature> ) (<perimeterWidth> 0.58 </perimeterWidth> ) (<profileName> ABS </profileName> ) (<procedureName> carve </procedureName> ) (<procedureName> bottom </procedureName> ) (<procedureName> preface </procedureName> ) (<procedureName> inset </procedureName> ) (<procedureName> fill </procedureName> ) (<procedureName> speed </procedureName> ) (<procedureName> temperature </procedureName> ) (<procedureName> raft </procedureName> ) (<procedureName> comb </procedureName> ) (<procedureName> wipe </procedureName> ) (<procedureName> export </procedureName> ) (</extruderInitialization> ) (<crafting> ) M113 S1.0 M108 S255.0 M104 S225.0 (<layer> 0.5 ) (<nestedRing> ) (<boundaryPerimeter> ) (<boundaryPoint> X-43.942 Y-30.13 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-42.861 Y-30.302 Z0.5 </boundaryPoint> ) (<boundaryPoint> X27.14 Y-30.302 Z0.5 </boundaryPoint> ) (<boundaryPoint> X28.221 Y-30.13 Z0.5 </boundaryPoint> ) (<boundaryPoint> X29.197 Y-29.633 Z0.5 </boundaryPoint> ) (<boundaryPoint> X29.959 Y-28.871 Z0.5 </boundaryPoint> ) (<boundaryPoint> X30.102 Y-28.656 Z0.5 </boundaryPoint> ) (<boundaryPoint> X30.469 Y-27.882 Z0.5 </boundaryPoint> ) (<boundaryPoint> X30.7 Y-26.341 Z0.5 </boundaryPoint> ) (<boundaryPoint> X30.857 Y-22.741 Z0.5 </boundaryPoint> ) (<boundaryPoint> X31.458 Y-18.171 Z0.5 </boundaryPoint> ) (<boundaryPoint> X31.448 Y-17.634 Z0.5 </boundaryPoint> ) (<boundaryPoint> X31.619 Y-16.555 Z0.5 </boundaryPoint> ) (<boundaryPoint> X31.308 Y-14.592 Z0.5 </boundaryPoint> ) (<boundaryPoint> X30.405 Y-12.822 Z0.5 </boundaryPoint> ) (<boundaryPoint> X29.0 Y-11.418 Z0.5 </boundaryPoint> ) (<boundaryPoint> X28.376 Y-11.099 Z0.5 </boundaryPoint> ) (<boundaryPoint> X27.969 Y-10.747 Z0.5 </boundaryPoint> ) (<boundaryPoint> X26.634 Y-9.896 Z0.5 </boundaryPoint> ) (<boundaryPoint> X25.076 Y-8.653 Z0.5 </boundaryPoint> ) (<boundaryPoint> X23.648 Y-7.261 Z0.5 </boundaryPoint> ) (<boundaryPoint> X22.366 Y-5.734 Z0.5 </boundaryPoint> ) (<boundaryPoint> X21.244 Y-4.087 Z0.5 </boundaryPoint> ) (<boundaryPoint> X20.291 Y-2.336 Z0.5 </boundaryPoint> ) (<boundaryPoint> X19.515 Y-0.497 Z0.5 </boundaryPoint> ) (<boundaryPoint> X18.927 Y1.407 Z0.5 </boundaryPoint> ) (<boundaryPoint> X18.532 Y3.361 Z0.5 </boundaryPoint> ) (<boundaryPoint> X18.334 Y5.345 Z0.5 </boundaryPoint> ) (<boundaryPoint> X18.334 Y7.339 Z0.5 </boundaryPoint> ) (<boundaryPoint> X18.485 Y8.851 Z0.5 </boundaryPoint> ) (<boundaryPoint> X19.34 Y10.104 Z0.5 </boundaryPoint> ) (<boundaryPoint> X20.622 Y11.632 Z0.5 </boundaryPoint> ) (<boundaryPoint> X22.049 Y13.024 Z0.5 </boundaryPoint> ) (<boundaryPoint> X23.608 Y14.268 Z0.5 </boundaryPoint> ) (<boundaryPoint> X25.284 Y15.35 Z0.5 </boundaryPoint> ) (<boundaryPoint> X27.058 Y16.259 Z0.5 </boundaryPoint> ) (<boundaryPoint> X28.913 Y16.988 Z0.5 </boundaryPoint> ) (<boundaryPoint> X30.834 Y17.527 Z0.5 </boundaryPoint> ) (<boundaryPoint> X32.797 Y17.873 Z0.5 </boundaryPoint> ) (<boundaryPoint> X34.785 Y18.023 Z0.5 </boundaryPoint> ) (<boundaryPoint> X36.779 Y17.973 Z0.5 </boundaryPoint> ) (<boundaryPoint> X38.375 Y17.764 Z0.5 </boundaryPoint> ) (<boundaryPoint> X38.912 Y17.775 Z0.5 </boundaryPoint> ) (<boundaryPoint> X40.011 Y17.602 Z0.5 </boundaryPoint> ) (<boundaryPoint> X41.972 Y17.913 Z0.5 </boundaryPoint> ) (<boundaryPoint> X43.742 Y18.814 Z0.5 </boundaryPoint> ) (<boundaryPoint> X45.148 Y20.22 Z0.5 </boundaryPoint> ) (<boundaryPoint> X46.05 Y21.989 Z0.5 </boundaryPoint> ) (<boundaryPoint> X46.361 Y23.951 Z0.5 </boundaryPoint> ) (<boundaryPoint> X46.05 Y25.913 Z0.5 </boundaryPoint> ) (<boundaryPoint> X45.148 Y27.683 Z0.5 </boundaryPoint> ) (<boundaryPoint> X43.742 Y29.088 Z0.5 </boundaryPoint> ) (<boundaryPoint> X41.972 Y29.991 Z0.5 </boundaryPoint> ) (<boundaryPoint> X40.011 Y30.302 Z0.5 </boundaryPoint> ) (<boundaryPoint> X38.048 Y29.991 Z0.5 </boundaryPoint> ) (<boundaryPoint> X37.98 Y29.956 Z0.5 </boundaryPoint> ) (<boundaryPoint> X37.45 Y29.879 Z0.5 </boundaryPoint> ) (<boundaryPoint> X31.828 Y28.105 Z0.5 </boundaryPoint> ) (<boundaryPoint> X23.311 Y26.218 Z0.5 </boundaryPoint> ) (<boundaryPoint> X14.662 Y25.079 Z0.5 </boundaryPoint> ) (<boundaryPoint> X6.132 Y24.698 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-12.788 Y24.628 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-13.715 Y24.405 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-14.584 Y24.045 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-15.387 Y23.553 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-16.103 Y22.941 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-16.715 Y22.225 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-17.207 Y21.422 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-17.567 Y20.553 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-17.789 Y19.627 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-17.861 Y8.553 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-17.389 Y8.295 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-16.852 Y9.349 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-16.208 Y10.34 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-15.464 Y11.26 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-14.627 Y12.096 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-13.708 Y12.84 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-12.716 Y13.485 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-11.662 Y14.022 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-10.558 Y14.445 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-9.415 Y14.752 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-8.247 Y14.937 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-7.066 Y14.998 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-5.885 Y14.937 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-4.717 Y14.752 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-3.574 Y14.445 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-2.47 Y14.022 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-1.416 Y13.485 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-0.424 Y12.84 Z0.5 </boundaryPoint> ) (<boundaryPoint> X0.495 Y12.096 Z0.5 </boundaryPoint> ) (<boundaryPoint> X1.332 Y11.26 Z0.5 </boundaryPoint> ) (<boundaryPoint> X2.076 Y10.34 Z0.5 </boundaryPoint> ) (<boundaryPoint> X2.72 Y9.349 Z0.5 </boundaryPoint> ) (<boundaryPoint> X3.257 Y8.295 Z0.5 </boundaryPoint> ) (<boundaryPoint> X3.681 Y7.19 Z0.5 </boundaryPoint> ) (<boundaryPoint> X3.987 Y6.048 Z0.5 </boundaryPoint> ) (<boundaryPoint> X4.172 Y4.88 Z0.5 </boundaryPoint> ) (<boundaryPoint> X4.234 Y3.699 Z0.5 </boundaryPoint> ) (<boundaryPoint> X4.172 Y2.517 Z0.5 </boundaryPoint> ) (<boundaryPoint> X3.987 Y1.349 Z0.5 </boundaryPoint> ) (<boundaryPoint> X3.681 Y0.207 Z0.5 </boundaryPoint> ) (<boundaryPoint> X3.257 Y-0.898 Z0.5 </boundaryPoint> ) (<boundaryPoint> X2.72 Y-1.952 Z0.5 </boundaryPoint> ) (<boundaryPoint> X2.076 Y-2.943 Z0.5 </boundaryPoint> ) (<boundaryPoint> X1.332 Y-3.863 Z0.5 </boundaryPoint> ) (<boundaryPoint> X0.495 Y-4.699 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-0.424 Y-5.443 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-1.416 Y-6.088 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-2.47 Y-6.625 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-3.574 Y-7.048 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-4.717 Y-7.355 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-5.885 Y-7.54 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-7.066 Y-7.601 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-8.247 Y-7.54 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-9.415 Y-7.355 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-10.558 Y-7.048 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-11.662 Y-6.625 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-12.716 Y-6.088 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-13.708 Y-5.443 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-14.627 Y-4.699 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-15.464 Y-3.863 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-16.208 Y-2.943 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-16.852 Y-1.952 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-17.389 Y-0.898 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-17.863 Y-1.189 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-17.893 Y-17.929 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-17.992 Y-18.549 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-18.154 Y-19.156 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-18.379 Y-19.742 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-18.664 Y-20.302 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-19.006 Y-20.828 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-19.402 Y-21.316 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-19.846 Y-21.76 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-20.334 Y-22.156 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-20.86 Y-22.498 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-21.42 Y-22.783 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-22.006 Y-23.008 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-22.613 Y-23.17 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-23.233 Y-23.269 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-42.861 Y-23.302 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-43.942 Y-23.473 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-44.902 Y-23.962 Z0.5 </boundaryPoint> ) (<boundaryPoint> X-44.902 Y-29.641 Z0.5 </boundaryPoint> ) (<perimeterPath> ) M108 S102.0 G1 X52.0 Y-57.0 Z10.0 F1920.0 G1 X52.0 Y-55.0 Z10.0 F1920.0 G1 X52.0 Y-30.0 Z10.0 F1920.0 G1 X51.93 Y-29.43 Z0.5 F1920.0 G1 X45.38 Y26.16 Z0.5 F1920.0 G1 X45.31 Y26.73 Z0.5 F1440.0 M101 G1 X44.91 Y27.51 Z0.5 F1440.0 G1 X43.57 Y28.85 Z0.5 F1440.0 G1 X41.88 Y29.71 Z0.5 F1440.0 G1 X40.01 Y30.01 Z0.5 F1440.0 G1 X38.14 Y29.71 Z0.5 F1440.0 G1 X38.07 Y29.68 Z0.5 F1440.0 G1 X37.52 Y29.6 Z0.5 F1440.0 G1 X31.9 Y27.82 Z0.5 F1440.0 G1 X23.36 Y25.93 Z0.5 F1440.0 G1 X14.69 Y24.79 Z0.5 F1440.0 G1 X6.14 Y24.41 Z0.5 F1440.0 G1 X-12.75 Y24.34 Z0.5 F1440.0 G1 X-13.63 Y24.13 Z0.5 F1440.0 G1 X-14.45 Y23.79 Z0.5 F1440.0 G1 X-15.22 Y23.32 Z0.5 F1440.0
Re: Starting a Prusa Mendel build September 16, 2011 08:30PM |
Re: Starting a Prusa Mendel build September 16, 2011 08:32PM |
Re: Starting a Prusa Mendel build September 17, 2011 01:29AM |
Re: Starting a Prusa Mendel build September 17, 2011 04:01AM |
Re: Starting a Prusa Mendel build September 17, 2011 04:18AM |
Re: Starting a Prusa Mendel build September 17, 2011 01:51PM |
Re: Starting a Prusa Mendel build September 17, 2011 06:49PM |
Re: Starting a Prusa Mendel build September 18, 2011 08:09PM |
Re: Starting a Prusa Mendel build September 19, 2011 11:33PM |
Re: Starting a Prusa Mendel build September 22, 2011 01:41PM |
Re: Starting a Prusa Mendel build September 25, 2011 01:30AM |
Re: Starting a Prusa Mendel build September 25, 2011 08:48AM |
Re: Starting a Prusa Mendel build September 25, 2011 10:59AM |
Re: Starting a Prusa Mendel build September 25, 2011 12:50PM |
Re: Starting a Prusa Mendel build September 27, 2011 04:34PM |
Re: Starting a Prusa Mendel build September 28, 2011 09:36AM |
Re: Starting a Prusa Mendel build September 28, 2011 09:45AM |
Re: Starting a Prusa Mendel build September 28, 2011 09:51AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: Starting a Prusa Mendel build September 28, 2011 11:21AM |
Re: Starting a Prusa Mendel build September 28, 2011 11:26AM |
Re: Starting a Prusa Mendel build September 28, 2011 11:00PM |
Re: Starting a Prusa Mendel build September 29, 2011 09:24AM |
Re: Starting a Prusa Mendel build September 29, 2011 11:26AM |
Re: Starting a Prusa Mendel build September 29, 2011 11:33AM |
Re: Starting a Prusa Mendel build September 29, 2011 12:04PM |
//// MOVEMENT SETTINGS const int NUM_AXIS = 4; // The axis order in all axis related arrays is X, Y, Z, E float max_feedrate[] = {200000, 200000, 240, 500000}; float homing_feedrate[] = {1500,1500,120}; bool axis_relative_modes[] = {false, false, false, false};
Re: Starting a Prusa Mendel build September 29, 2011 04:53PM |
