Achatz marlin firmware error in arduino programmer April 15, 2015 01:47PM |
Arduino: 1.6.3 (Windows 8.1), Board: "Sanguino W/ ATmega1284p 16mhz" Using library LiquidCrystal in folder: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10603 -DARDUINO_AVR_ATMEGA1284 -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src C:\Users\Vincent\AppData\Local\Temp\build591782319819229632.tmp\cardreader.cpp -o C:\Users\Vincent\AppData\Local\Temp\build591782319819229632.tmp\cardreader.cpp.o In file included from C:\Users\Vincent\AppData\Local\Temp\build591782319819229632.tmp\cardreader.h:6:0, from C:\Users\Vincent\AppData\Local\Temp\build591782319819229632.tmp\cardreader.cpp:2: C:\Users\Vincent\AppData\Local\Temp\build591782319819229632.tmp\SdFile.h:41:14: error: conflicting return type specified for 'virtual size_t SdFile::write(uint8_t)' size_t write(uint8_t b); ^ In file included from C:\Users\Vincent\AppData\Local\Temp\build591782319819229632.tmp\SdFile.h:28:0, from C:\Users\Vincent\AppData\Local\Temp\build591782319819229632.tmp\cardreader.h:6, from C:\Users\Vincent\AppData\Local\Temp\build591782319819229632.tmp\cardreader.cpp:2: C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:40:18: error: overriding 'virtual void Print::write(uint8_t)' virtual void write(uint8_t) = 0; ^ In file included from C:\Users\Vincent\AppData\Local\Temp\build591782319819229632.tmp\ultralcd.h:5:0, from C:\Users\Vincent\AppData\Local\Temp\build591782319819229632.tmp\cardreader.cpp:3: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:83:18: error: conflicting return type specified for 'virtual size_t LiquidCrystal::write(uint8_t)' virtual size_t write(uint8_t); ^ In file included from C:\Users\Vincent\AppData\Local\Temp\build591782319819229632.tmp\SdFile.h:28:0, from C:\Users\Vincent\AppData\Local\Temp\build591782319819229632.tmp\cardreader.h:6, from C:\Users\Vincent\AppData\Local\Temp\build591782319819229632.tmp\cardreader.cpp:2: C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:40:18: error: overriding 'virtual void Print::write(uint8_t)' virtual void write(uint8_t) = 0; ^ Error compiling.
Re: Achatz marlin firmware error in arduino programmer April 18, 2015 04:31PM |
Re: Achatz marlin firmware error in arduino programmer May 16, 2015 01:02PM |
Re: Achatz marlin firmware error in arduino programmer May 16, 2015 08:01PM |
Re: Achatz marlin firmware error in arduino programmer June 07, 2015 04:36AM |
Re: Achatz marlin firmware error in arduino programmer June 07, 2015 05:00AM |
