Hey everyone,
So I have an anet a8 that I put a ramps 1.4 on, with the latest version of Marlin (not positive of the ver #, but it's the latest as of 3/10/2018). It's got an inductive sensor that I finally got functioning properly.
I have two issues I'm trying work through. For one, when I run a G28 to home it all, the z_safe_homing function doesn't kick in (I do have it enabled), so it tries to home Z off the bed. I can home XY separately, manually move to a safe area of the bed, and then home Z and it works as it should.
Second, after homing Z, when I try to run a G29 for auto bed leveling, it will probe the first corner of the bed (as I have it set up in firmware), but then, instead of going right in the +X direction, it goes left.
I've attached my config.h file if there are any questions.
Thanks!
