heated bed May 24, 2018 06:54PM |
Re: heated bed May 24, 2018 08:07PM |
Re: heated bed May 24, 2018 11:12PM |
Re: heated bed May 25, 2018 02:23AM |
Roberts_Clif
Yes, Most heat beds work with 12 or 24 volts.
When using a 12v controller you can drive the heat-bed with a SSR
Before connecting to 24volts make sure your hot-bed will handle the power. (as fire can result from overpowering a hot-bed heater)
Re: heated bed May 25, 2018 10:24AM |
Re: heated bed May 25, 2018 06:59PM |
Re: heated bed May 25, 2018 07:38PM |
What do you think o_lampe!Quote
o_lampe
Re: heated bed May 25, 2018 08:07PM |
Re: heated bed May 25, 2018 08:55PM |
Re: heated bed May 25, 2018 09:19PM |
Re: heated bed May 26, 2018 02:57AM |
The steppers on my 12 volt supply are
My 12Volt Current vref X, Y, E0, and E1 = 0.695V
My 12Volt Current vref Z = 1.396V ; Dual Steppers wired in parallel
The steppers on my 24 volt supply are about half the 12 volt vref.
My 12Volt Current vref X, Y, E0, and E1 = 0.395V
My 12Volt Current vref Z = 0.710V ; Dual Steppers wired in parallel
Re: heated bed May 26, 2018 03:57AM |
Re: heated bed May 26, 2018 08:52AM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: heated bed May 26, 2018 10:12AM |
o_lampe
But lets stay focussed on the bed SSR stuff.
Re: heated bed May 26, 2018 06:44PM |
Re: heated bed May 29, 2018 05:45PM |
Re: heated bed May 30, 2018 10:23PM |
Re: heated bed May 31, 2018 02:32AM |
Re: heated bed May 31, 2018 05:32AM |
Re: heated bed May 31, 2018 12:57PM |
Re: heated bed May 31, 2018 04:38PM |
Re: heated bed May 31, 2018 07:52PM |
Re: heated bed June 01, 2018 06:33PM |
Re: heated bed June 07, 2018 11:44PM |
Re: heated bed June 09, 2018 08:47PM |
Re: heated bed June 26, 2018 06:16PM |
Re: heated bed January 21, 2019 10:40AM |
o_lampe
Vref is independend of Vin. Maybe if your steppers are a bad match for the printer settings, they "get alive" at 24V and you can reduce Vref.
A 600W ATX PSU sure doesn't deliver 600W on 12V. That's 50A on 12V.
They have 5V and 3.3V output too, which share the 600W......is there a label for max. currents on the PSU?
Feeding 24V directly to the controller is only possible with a few 8-bit Atmega controllers. Even then, a 300W bed is a lot of current for the PCB.
You might need a DC-DC SSR or external Mosfet module to feed 12V to the controller and 24V to the bed. Don't pick up a (fake) AC-DC SSR, they get very hot.
Settings for My 3DP12 V-Ref current below for a 24 volt supply X, Y, E0 and E1 = 0.395v // Only Date on Steppers - it has 5.5 ohms Z Dual Stepper = 0.710v // 42SHD0026-20B Steppers for a 12 volt supply X, Y, E0 and E1 = 0.695v // 24HD4027-01 Steppers Z Dual Stepper = 1.396v // 24HD2037-01 Steppers
