Sunhokey Prusa i3 Kit from ebay March 21, 2015 03:58AM |
Re: Sunhokey Prusa i3 Kit from ebay March 21, 2015 05:01AM |
Re: Sunhokey Prusa i3 Kit from ebay March 21, 2015 06:59AM |
Re: Sunhokey Prusa i3 Kit from ebay March 21, 2015 11:45AM |
Re: Sunhokey Prusa i3 Kit from ebay April 26, 2015 01:40AM |
Re: Sunhokey Prusa i3 Kit from ebay April 26, 2015 05:33AM |
Re: Sunhokey Prusa i3 Kit from ebay April 26, 2015 07:34PM |
Zavashier
Acrylic frames are rubbish. Otherwise, there's good and bad about this kit. Good : hotend, leadscrews, belt tensioning. Bad : acrylic frame and parts, extruder, bearings.
Re: Sunhokey Prusa i3 Kit from ebay May 08, 2015 09:52PM |
Re: Sunhokey Prusa i3 Kit from ebay May 08, 2015 10:36PM |
Re: Sunhokey Prusa i3 Kit from ebay May 08, 2015 10:42PM |
wait, so you uploaded a different marlin config and it works now as in axis moving, LCD works etc.? because the company sent me the configuration file as well as the main marlin files and I tried uploading the files to the printer but have not gotten any form of luck in terms of restoring it to how it previously was. Would really appreciate if someone could help.Quote
ffneil
I did the same thing and have loaded another merlin config file. It works but the setting are not correct. I too need to original and can't find any info on the internet
Re: Sunhokey Prusa i3 Kit from ebay May 09, 2015 01:58PM |
Re: Sunhokey Prusa i3 Kit from ebay May 09, 2015 02:18PM |
Re: Sunhokey Prusa i3 Kit from ebay May 09, 2015 07:59PM |
well I cant exactly say im a fan of acrylic frames. I will say however they look cool. But I guess if the purpose of a printer was to look cool rather serve any use than mine is doing a hell of a job, considering I haven't been able to get the firmware to work again.Quote
Vanbot
OK I don't like acrylic frames anymore. At least not acrylic bed frames. Mine broke with a minor impact.
Re: Sunhokey Prusa i3 Kit from ebay May 09, 2015 08:11PM |
I have the files, they sent me them so ill share it here should anybody ever find themselves needing it. Ill post the modified one that I tried making changes to in order to get my e3d lite 6 to work with it (just incase somebody can help me out with that) and the non modified version from sunhokey (PLEASE NOTE, THE MODIFED E3D AND STOCK FILE MAY OR NOT WORK, SHOULD SOMETHING GO WRONG IN THE PROCESS I WILL NOT BE HELD RESPONSIBLE FOR ANY MISTAKES MADE, THESE FILES WERE GIVEN TO ME DIRECTLY FROM SUNHOKEY, USE AT YOUR DISCRETION)Quote
ffneil
Yes I have it working, but the steppers are not going ok the correct distance, and the LCD is ok but not the way it was when I first turned it on. Can you share the files you have and/or point me in the direction to get the files from the company? Thanks
P.S. Attached is Merlin config that work but needs lots of tuning.
Re: Sunhokey Prusa i3 Kit from ebay May 09, 2015 08:41PM |
Re: Sunhokey Prusa i3 Kit from ebay May 09, 2015 08:48PM |
Re: Sunhokey Prusa i3 Kit from ebay May 09, 2015 09:12PM |
this link mentions something about a ICSP pin being used to program it with new firmware, but I have not been able to find anything [reprap.org]Quote
ffneil
Try changing the baud rate. #define BAUDRATE 250000
Re: Sunhokey Prusa i3 Kit from ebay May 10, 2015 02:55PM |
Re: Sunhokey Prusa i3 Kit from ebay May 10, 2015 07:32PM |
Re: Sunhokey Prusa i3 Kit from ebay June 07, 2015 09:33AM |
Re: Sunhokey Prusa i3 Kit from ebay July 23, 2015 08:14AM |
Re: Sunhokey Prusa i3 Kit from ebay July 23, 2015 09:29AM |
