What about the current supplied to the motor? I used Tom Sandlandarer's tips on adjusting the motor current supplied by turning it up slowly, but mine a slight hassle, turn off printer, turn a bit around 1/8 turn then test again, and repeat
It probably about the acceleration too, I remember I get this issue when I put on my other electronic (no stock firmware from supplier and prior knowledge configuring it). And also try to use prusa calculator much easier compared to using '3200/1.25' (no offense on this =))
Also make sure the lead screw can be turned freely all the way from end to end to check if it will be good or not
Another thing might be both ends are not leveled
