This is underextrusion. Cause could be a few things. Does your extruder click click click? If so, your nozzle is clogged of the filament isn't sliding through everything... Can you manually push the filament through? Also, make sure the filament is coming off its spool easy...
Secondly, your extrusion temp could be too low, eg, even if your printer SAYS its extruding at 210c, you need to verify that with a meter.
Another thing it could be is your stepper driver isn't giving the stepper enough current, see if the extruder pushes the filament through when it's not connected to the hot end..
Finally, your extruder steps could be wrong, Google "calibrate extruder steps" for more details...
Edited 1 time(s). Last edit at 11/07/2015 01:30PM by Qdeathstar.
