Why does my Prusa i3 not put the item in the same place as Cura?
Posted by vertis
December 29, 2015 07:11PM
Hi All,
New to the RepRap community, so I apologise if this is a dumb question. When I place an item on the platform in Cura it isn't in the same place on the actual build platform of my Prusa i3 (particularly the Y axis). Can anyone give me some hints as to why this would be the case?
Some background:
I just built a Prusa i3 from a kit (migbot).
I went straight to using Cura because I've been using Cura for a while now with my Ultimaker 2. Currently 15.02.1
I added another machine, and tweaked a few of the settings including the platform dimensions 200mmx200mmx180mm and it works nicely, except for the fact that when I place an item in the middle of the platform on Cura it is wrong on the Y axis.
I played with the setting Center (0,0) but that actually makes the problem worse.
I haven't tweaked the start/end gcode at all, but I've included it below for completeness. Any help is greatly appreciated.
Start gcode:
;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21        ;metric values
G90        ;absolute positioning
M82        ;set extruder to absolute mode
M107       ;start with the fan off
G28 X0 Y0  ;move X/Y to min endstops
G28 Z0     ;move Z to min endstops
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
G92 E0                  ;zero the extruded length
G1 F200 E3              ;extrude 3mm of feed stock
G92 E0                  ;zero the extruded length again
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing...
end gcode:
;End GCode
M104 S0                     ;extruder heater off
M140 S0                     ;heated bed heater off (if you have it)
G91                                    ;relative positioning
G1 E-1 F300                            ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
G28 X0 Y0                              ;move X/Y to min endstops, so the head is out of the way
M84                         ;steppers off
;{profile_string}
Re: Why does my Prusa i3 not put the item in the same place as Cura?
December 30, 2015 02:41AM
I'm not sure, which firmware migbot uses, but maybe there is a section where the bed size is defined:
// @section machine
// Travel limits after homing (units are in mm)
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define X_MAX_POS 200
#define Y_MAX_POS 200
#define Z_MAX_POS 200
Your Cura settings should match those in firmware.
-Olaf
January 03, 2016 01:01PM
Maybe you have the y and x axis switched, had the same problem.
Check if the motors are on the right place and if not dont forget to switch the endstops too.
January 03, 2016 06:20PM
Thank you both.
It turned out I did need to fool around in the firmware. I had wrongly assumed that the preloaded firmware that came with it would have been correctly configured.
For anyone else that has this problem https://github.com/garynmckinney/3DPrinter has the correctly configured firmware for the Migbot variant.
