Can Anet A8 controller handle two extruders? April 29, 2018 02:09AM |
Re: Can Anet A8 controller handle two extruders? April 29, 2018 02:55AM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: Can Anet A8 controller handle two extruders? April 30, 2018 12:47PM |
Re: Can Anet A8 controller handle two extruders? May 18, 2018 12:01PM |
Re: Can Anet A8 controller handle two extruders? September 10, 2020 11:40AM |
dlc60
All,
I have a Tevo Tarantula kit and Rumba board I will be using with it to do a Chimera printer. A good deal came my way and I am intrigued by the roller wheels instead of linear "glides" to move everything around - I suspect the rollers will be far smoother than the cheap linear bearings that usually come with these cheap printers...
Anyway.
So I decided to upgrade my A8 with a E3Dv6 and a "Itty bitty belted" extruder on a direct mount so I can do flexible filaments. Same number of steppers, heaters, etc. so the hardware will work for me.
Between the time when I first started this project and now I have put Raspberry Pi's with Octoprint on my printers, and discovered that the Anet firmware does not have temperature overrun safeties built in. AND I will be going from about 80 steps/mm on the extruder to about 660/mm. Clearly, new firmware is a requirement. And speaking of the extruder, I will be happy to get rid of the current firmware's extruder "stutter" which doesn't give the nicest results.
The latest Marlin has a board entry for this board, so most of the setup will be done already.
As soon as I have the new print head and gantry installed I'll fire up the new firmware and see how it handles the X endstop being off to the side of the bed and see if the Anet A8 controller really does have digipots.
DLC
Re: Can Anet A8 controller handle two extruders? September 10, 2020 09:07PM |
Re: Can Anet A8 controller handle two extruders? September 10, 2020 09:19PM |
Re: Can Anet A8 controller handle two extruders? September 10, 2020 09:54PM |
