Structure reinforcment and enlargment of belt idler carriages August 22, 2015 02:26PM |
Re: Structure reinforcment and enlargment of belt idler carriages August 22, 2015 06:04PM |
Re: Structure reinforcment and enlargment of belt idler carriages August 23, 2015 06:53AM |
Re: Structure reinforcment and enlargment of belt idler carriages August 23, 2015 07:50AM |
That's exactly what I've done on my test machine. I've merged the bottom two motor mounts into one and added a 2mm stop at the bottom - the STL is attached, if you're interested.Quote
bgkdavis
The idea of modifying the lower motor mounts to prevent slippage I like, but isnt the top plate supposed to use the rails to brace the belt tension in much the same way? The instructions are very clear about slackening belts before removing top for this reason.
.... Id be looking at better ways of using the rails to brace the belt tension before stiffening the pannels, maybe extend your idea for the feet to the idler suports?
Re: Structure reinforcment and enlargment of belt idler carriages August 23, 2015 08:17AM |
Re: Structure reinforcment and enlargment of belt idler carriages August 23, 2015 08:28AM |
Re: Structure reinforcment and enlargment of belt idler carriages August 23, 2015 08:42AM |
Re: Structure reinforcment and enlargment of belt idler carriages August 23, 2015 09:10AM |
I personally wouldn't bother trying putting screws pushing against the ends of the rods. I had that setup on the x axis of my MendelMax (among others that I can't think of right now), and it really doesn't work very well. I guess if you can manage to make it work then great, but it seems to be a more complicated way of doing things.Quote
bgkdavis
I've got a very similar plate in mind, but it will sit on top of the top plate, this way I maintain the positional keying feature of the top plate, and get to transfer the force to the rods.
I've got a further idea where I can use some screws acting on the ends of the rods to do the belt tension function, but that may end up make dismantling very difficult
would you care to share the file your lower motor mounts
Re: Structure reinforcment and enlargment of belt idler carriages August 23, 2015 09:15AM |
Re: Structure reinforcment and enlargment of belt idler carriages August 23, 2015 12:58PM |
Re: Structure reinforcment and enlargment of belt idler carriages September 03, 2015 03:23AM |
Re: Structure reinforcment and enlargment of belt idler carriages September 03, 2015 03:25AM |
Re: Structure reinforcment and enlargment of belt idler carriages September 05, 2015 01:35PM |
Re: Structure reinforcment and enlargment of belt idler carriages September 05, 2015 01:42PM |
Re: Structure reinforcment and enlargment of belt idler carriages September 05, 2015 07:21PM |
Re: Structure reinforcment and enlargment of belt idler carriages September 06, 2015 02:38AM |
