Squares are not square September 05, 2015 07:59AM |
Re: Squares are not square September 05, 2015 12:07PM |
Re: Squares are not square September 05, 2015 12:31PM |
Re: Squares are not square September 05, 2015 12:39PM |
ambrop7
I think the issue is that the stock firmware in the automatic calibration procedure actually adjusts the various delta parameters (endstop positions, delta radius and diagonal rod length) rather than just compensates height, which achieves flatness but messes up the shape and size.
Re: Squares are not square September 05, 2015 12:46PM |
dc42
It only adjusts diagonal rod length if you use 7-factor calibration, which I don't recommend because the diagonal rod length (a) should be known, and (b) isn't easy to establish by probing, because changing it only affects the flatness of the printing plane slightly if you make a corresponding change in the delta radius.
You can choose to calibrate 3, 4, 6 or 7 parameters automatically. Or none if that's what you really want.
Re: Squares are not square September 05, 2015 12:53PM |
Re: Squares are not square September 05, 2015 12:58PM |
PRZ
About your Firmware, I don't want to discourage you, but the big advantage of the duet/RRP is the control by the web server. If you don't propose something equivalent, you won't get many chances.
Re: Squares are not square September 05, 2015 12:59PM |
ambrop7
dc42
Maybe it would help if the input to the calibration wasn't just bed probing (heights at various points), but also one or more measurements of the XY distance between two points? I found I can do such measurements by slightly colliding the nozzle into some paper on the bed, which leaves an imprint. I know it can't be automatic (would need user assistance), but with this info it should be possible to prevent over-adjustment of the parameters and calibrate the size and shape too not just the bed height.
Re: Squares are not square September 05, 2015 01:12PM |
Re: Squares are not square September 05, 2015 01:18PM |
PRZ
You could have a better result than trying to measure the distance on a paper,
Re: Squares are not square September 05, 2015 01:30PM |
Re: Squares are not square September 05, 2015 01:44PM |
PRZ
David,
1. I run the 1.09d firmware. Was there modifications on the calibration since ?
2. My aluminium bed is reasonnably flat (that was the motive to change it, the original bed was completely warped).
My bed was NOT perpendicular to the the towers, and that was the point of my post, to explain what could be the consequences.
3. Done
4. I systematically run the 7 points/ 6 parameters calibration, because I got less problem with that than with the 4 points calibration. What is the point to restrict to 4 points calibration ?
I solved the mechanical stability problems of the machine by renforcing it, but I created another instability by heating the bed with a light spot, which is required because the thermal conductivity of the aluminium bed created problems. I shall go back to wood/plastic bed, but a flat one. So a complete calibration is always needed.
5. (a) That was how I detected the problem
(b) I will do that
Re: Squares are not square September 05, 2015 02:02PM |
Re: Squares are not square September 05, 2015 02:10PM |
Martoh
...I should find how I can upgrade the firmware for the Duet since I'm still in 1.09c
Is there a tutorial on the subject ?
Re: Squares are not square September 05, 2015 02:39PM |
Re: Squares are not square September 05, 2015 02:52PM |
PRZ
It is more clear now that even if that drive to a larger deviation, having at least 3 points more than the adjusted parameters will give at the end better results.
Re: Squares are not square September 05, 2015 07:11PM |
