Whats your calibration deviation? August 10, 2015 04:54AM |
Re: Whats your calibration deviation? August 10, 2015 06:00AM |
Re: Whats your calibration deviation? August 13, 2015 02:26AM |
dc42
What you are seeing after the first two times you run G32 is the variation in trigger position of the homing microswitches and the bed probe switches. To see the contribution of each, take a copy of your bed.g file and change the S4 parameter on the final G30 command to S-1. When you run this, it will report the probe height errors, but not calibrate. Run it several times and see how reproducible they are. Then comment out the G28 command at the top of the file (so that it does not do homing), and run it several times again.
To get a good first layer when printing, I aim for a deviation no more than one quarter of my first layer height. I usually print at 0.2mm (not on a Fisher), so I aims for 0.05mm bed height precision.
Re: Whats your calibration deviation? August 13, 2015 03:53AM |
Re: Whats your calibration deviation? August 13, 2015 04:44AM |
Sash
I had a go at using S-1. Because my printer doesn't home itself entirely on its own for some reason I have to move all three towers to the top and trigger the micro switches. From that point I can hit 'Home All' and it will complete the homing and drop down to the build platform. I then ran G32 several times and this is what I got?
Re: Whats your calibration deviation? August 13, 2015 01:30PM |
bluesign2k
You're homing problem is odd. With the carriages NOT at their home position, what response do you get from M119?
Edit: actually, having just seen your screenshot, it thinks that the bed sensor is already being probed?! What value does the Z sensor read when this message is shown? What is the trigger level set to in your config file?
G31 X0 Y0 Z-0.1 P200 ; Set the zprobe height and threshold (put your own values here)
Re: Whats your calibration deviation? August 18, 2015 12:01PM |
I have my doubts about how the endstop switches are mounted on the Fisher. Most delta printers mount the switches horizontally and upside down, so that the carriages run into them. I find this gives highly reproducible results. On the Fischer, the sideways mounting arrangement looks to me that it needs a larger amount of carriage travel to cause the same amount of switch depression, which I suspect will make the trigger position more variable.
Re: Whats your calibration deviation? August 21, 2015 03:44AM |
Re: Whats your calibration deviation? August 21, 2015 04:21AM |
