Homing works calibration doesn't..... August 17, 2015 12:07PM |
Re: Homing works calibration doesn't..... August 17, 2015 12:30PM |
Re: Homing works calibration doesn't..... August 17, 2015 01:50PM |
dc42
Hi Sash,
I suggest you take a look at the section on the auto calibration file at [reprap.org]. In particular:
1. Use 6-point calibration, not 7 point.
2. After running it several times, copy the parameters to the M665 and M666 commands in config.g. Then it should no longer drag the nozzle across the bed when you run it.
3. Create a macro file called e,g, "Check bed" similar to bed.g but with S-1 on the final G30 command, to probe the bed and print the height errors without changing anything. Let us know what it reports.
6:26:56 PM M98 P/macros/calcbed.g Bed probe heights: 0.146 -0.164 0.154 -0.129 0.123 -0.106 -0.029, mean -0.001, deviation from mean 0.129 6:24:50 PM G32 Calibrated 6 factors using 7 points, deviation before 0.141 after 0.128 6:22:49 PM G32 Calibrated 6 factors using 7 points, deviation before 0.269 after 0.130 6:20:46 PM Calibrated 6 factors using 7 points, deviation before 2.925 after 0.092 6:20:24 PM G32 Error: Z probe warning: probe already triggered at start of probing move
;M561 G31 X0 Y0 ; don't want any probe offset for this ;G28 ; Probe the bed and do 6-factor auto calibration G1 X-49.00 Y-33.00 F500 G4 P300 G30 P0 X-49.00 Y-33.00 Z-99999 ; X tower G4 P300 G1 X0 Y-60 F500 G4 P300 G30 P1 X0 Y-60 Z-99999 ; between X and Y towers G4 P300 G1 X58 Y-32 F500 ; Y tower G4 P300 G30 P2 X58 Y-32 Z-99999 ; Y tower G4 P300 G1 X60 Y23 F500 G4 P300 G30 P3 X60 Y23 Z-99999 ; between Y and Z towers G4 P300 G1 X0 Y60 F500 G4 P300 G30 P4 X0 Y60 Z-99999 ; Z tower G4 P300 G1 X-58 Y32 F500 G4 P300 G30 P5 X-58 Y32 Z-99999 ; between Z and X towers G4 P300 G1 X0 Y0 F500 G30 P6 X0 Y0 Z-99999 S6 ; centre, and auto-calibrate 6 factors
Re: Homing works calibration doesn't..... August 17, 2015 04:33PM |
Re: Homing works calibration doesn't..... August 18, 2015 03:18AM |
dc42
It appears to me that either your bed switches or your homing switches are giving very variable results. Try running calcbed.g several times, without any intervening G32 commands, to hee how reproducible the combination of homing switches + bed switches is. Then comment out the G28 command at the start of calcbed.g and run it again several times, to see how reproducible the bed switches are by themselves.
7:54:24 AM Bed probe heights: 1.416 1.701 3.301 3.996 4.000 2.557 2.559, mean 2.790, deviation from mean 0.953 7:54:03 AM M98 P/MACROS/CALCBED.G Error: Z probe warning: probe already triggered at start of probing move 7:51:50 AM Bed probe heights: 1.427 1.712 3.301 4.007 4.000 2.557 2.582, mean 2.798, deviation from mean 0.950 7:51:29 AM M98 P/MACROS/CALCBED.G Error: Z probe warning: probe already triggered at start of probing move 7:49:32 AM Bed probe heights: 1.450 1.747 3.324 4.019 4.000 2.592 2.604, mean 2.819, deviation from mean 0.942 7:49:10 AM M98 P/MACROS/CALCBED.G Error: Z probe warning: probe already triggered at start of probing move 7:47:03 AM Bed probe heights: 1.450 1.758 3.324 4.007 4.000 2.569 2.604, mean 2.816, deviation from mean 0.939 7:46:42 AM M98 P/MACROS/CALCBED.G Error: Z probe warning: probe already triggered at start of probing move 7:44:25 AM Bed probe heights: 1.461 1.781 3.335 4.019 4.000 2.592 2.627, mean 2.831, deviation from mean 0.934 7:44:04 AM M98 P/MACROS/CALCBED.G Error: Z probe warning: probe already triggered at start of probing move
8:03:22 AM Bed probe heights: 1.930 2.055 3.312 3.916 4.000 3.003 2.787, mean 3.000, deviation from mean 0.758 8:03:02 AM M98 P/MACROS/CALCBED.G Error: Z probe warning: probe already triggered at start of probing move 8:01:52 AM Bed probe heights: 1.930 2.067 3.312 3.939 4.000 3.003 2.787, mean 3.005, deviation from mean 0.760 8:01:31 AM M98 P/MACROS/CALCBED.G Error: Z probe warning: probe already triggered at start of probing move 8:00:14 AM Bed probe heights: 1.278 1.667 3.289 3.996 4.000 2.546 2.524, mean 2.757, deviation from mean 0.988 7:59:52 AM M98 P/MACROS/CALCBED.G Error: Z probe warning: probe already triggered at start of probing move 7:58:39 AM Bed probe heights: 1.278 1.678 3.289 3.996 4.000 2.557 2.536, mean 2.762, deviation from mean 0.986 7:58:18 AM M98 P/MACROS/CALCBED.G Error: Z probe warning: probe already triggered at start of probing move 7:57:04 AM Bed probe heights: 1.290 1.678 3.301 3.984 4.000 2.557 2.547, mean 2.765, deviation from mean 0.982 7:56:43 AM M98 P/MACROS/CALCBED.G Error: Z probe warning: probe already triggered at start of probing move
Re: Homing works calibration doesn't..... August 18, 2015 03:34AM |
Re: Homing works calibration doesn't..... August 19, 2015 05:02AM |
dc42
You need to get rid of that error message. I am assuming that you have the M666 X Y Z parameters all set to zero. You have huge initial calibration errors, and the nozzle is dragging on the bed at one point when probing (the point that is giving the 4mm height error).
First, I suggest you increase the Z dive height. This is set by the H parameter of the M558 command in config.g. The default is 4mm, but you need to increase that until you have the calibration error sorted out.
Second, fix the calibration error. I think your homing switches are triggering at different heights.
M666 X0.0 Y0.0 Z0.0
M558 P4 X0 Y0 Z0 H6
>>>g28 SENDING:G28 >>>M98 P/MACROS/CALCBED.G SENDING:M98 P/MACROS/CALCBED.G Bed probe heights: 0.523 -0.082 -0.218 -0.483 -0.245 -0.452 -0.359, mean -0.188, deviation from mean 0.318 >>>g28 SENDING:G28 >>>M98 P/MACROS/CALCBED.G SENDING:M98 P/MACROS/CALCBED.G Bed probe heights: 0.523 -0.082 -0.195 -0.574 -0.199 -0.052 -0.119, mean -0.100, deviation from mean 0.301 >>>g28 SENDING:G28 >>>M98 P/MACROS/CALCBED.G SENDING:M98 P/MACROS/CALCBED.G Bed probe heights: 0.523 -0.082 -0.206 -0.574 -0.199 -0.064 -0.130, mean -0.105, deviation from mean 0.301 >>>g28 SENDING:G28 >>>M98 P/MACROS/CALCBED.G SENDING:M98 P/MACROS/CALCBED.G Bed probe heights: 0.511 -0.082 -0.206 -0.574 -0.210 -0.064 -0.130, mean -0.108, deviation from mean 0.299 >>>g28 SENDING:G28 >>>M98 P/MACROS/CALCBED.G SENDING:M98 P/MACROS/CALCBED.G Bed probe heights: 0.488 -0.082 -0.206 -0.586 -0.233 -0.075 -0.141, mean -0.119, deviation from mean 0.295
>>>M98 P/MACROS/CALCBED.G SENDING:M98 P/MACROS/CALCBED.G Bed probe heights: 0.420 -0.082 -0.206 -0.586 -0.233 -0.075 -0.141, mean -0.129, deviation from mean 0.276 >>>M98 P/MACROS/CALCBED.G SENDING:M98 P/MACROS/CALCBED.G Bed probe heights: 0.488 -0.094 -0.206 -0.586 -0.233 -0.075 -0.141, mean -0.121, deviation from mean 0.295 >>>M98 P/MACROS/CALCBED.G SENDING:M98 P/MACROS/CALCBED.G Bed probe heights: 0.477 -0.094 -0.218 -0.597 -0.245 -0.075 -0.141, mean -0.128, deviation from mean 0.296 >>>M98 P/MACROS/CALCBED.G SENDING:M98 P/MACROS/CALCBED.G Bed probe heights: 0.408 -0.116 -0.218 -0.597 -0.233 -0.075 -0.153, mean -0.141, deviation from mean 0.275 >>>M98 P/MACROS/CALCBED.G SENDING:M98 P/MACROS/CALCBED.G Bed probe heights: 0.408 -0.116 -0.206 -0.586 -0.222 -0.075 -0.153, mean -0.136, deviation from mean 0.271
Re: Homing works calibration doesn't..... August 19, 2015 09:54AM |
Re: Homing works calibration doesn't..... August 19, 2015 02:28PM |
>>>g28 SENDING:G28 >>>g32 SENDING:G32 Calibrated 6 factors using 7 points, deviation before 0.196 after 0.169 >>>g32 SENDING:G32 Calibrated 6 factors using 7 points, deviation before 0.164 after 0.164 >>>g32 SENDING:G32 Calibrated 6 factors using 7 points, deviation before 0.172 after 0.167 >>>g32 SENDING:G32 Calibrated 6 factors using 7 points, deviation before 0.177 after 0.164
Re: Homing works calibration doesn't..... August 19, 2015 03:48PM |
Re: Homing works calibration doesn't..... August 20, 2015 03:43AM |
Re: Homing works calibration doesn't..... August 20, 2015 05:23AM |
bluesign2k
I also plan on rebuilding the first printer from scratch this weekend, so I'll document my build method for those who are interested.
Re: Homing works calibration doesn't..... August 20, 2015 02:37PM |
bluesign2k
but frankly, all 4 of my printers print better than the Stratasys Dimension I have at work.
bluesign2k
Re: Homing works calibration doesn't..... August 23, 2015 10:08AM |
Re: Homing works calibration doesn't..... August 23, 2015 10:25PM |
Re: Homing works calibration doesn't..... August 24, 2015 03:47AM |
Re: Homing works calibration doesn't..... August 24, 2015 05:21AM |
Re: Homing works calibration doesn't..... August 24, 2015 10:34PM |
Re: Homing works calibration doesn't..... August 25, 2015 03:28AM |
Re: Homing works calibration doesn't..... August 25, 2015 05:16AM |
Re: Homing works calibration doesn't..... August 25, 2015 09:53AM |
M665 Diagonal 160.00, delta radius 81.00, homed height 180.00, bed radius 75.0, X 0.00°, Y 0.00°, Z 0.00° M666 Endstop adjustments X0.00 Y0.00 Z0.00Then did a 7 point probe (x, z opposite, y, x opposite, z, y opposite, centre):
Bed probe heights: 3.665 2.770 2.727 2.336 2.430 2.753 2.682, mean 2.766, deviation from mean 0.399After a few 10 point, 6 factor calibrations which ended up with a deviation of 0.066 - this is the only time I've ever seen the deviation below ~100 um setting 160 mm arms. The new settings it found were:
M665 Diagonal 160.00, delta radius 81.70, homed height 177.10, bed radius 75.0, X -0.03°, Y 0.64°, Z 0.00° M666 Endstop adjustments X-0.70 Y0.19 Z0.51With the 7 point probe now giving:
Bed probe heights: 0.069 -0.038 0.060 -0.085 0.012 -0.081 0.125, mean 0.009, deviation from mean 0.075
Re: Homing works calibration doesn't..... August 25, 2015 10:14PM |
Re: Homing works calibration doesn't..... August 26, 2015 02:50AM |
bluesign2k
