Re: skipping extruder! September 20, 2015 09:48PM |
Re: skipping extruder! September 20, 2015 11:05PM |
Re: skipping extruder! September 20, 2015 11:36PM |
Re: skipping extruder! September 21, 2015 02:01AM |
yes you always get one, it is the seal that gives you the pressure that makes the plastic come out of the nozzle. What I cannot explain is the double bulb though, perhaps it was an artefact from pulling it out?Quote
psneddon
Jelle - By saying "you can_not_not_get a 'bulb'" do you mean that you CAN get a bulb?
Re: skipping extruder! September 21, 2015 09:06AM |
Re: skipping extruder! September 21, 2015 09:10AM |
kellef
Okay, I finally removed the retraction completely and starter to use the web interface, the result was great, with no skipping! But now I have another problem! The retraction made the prints look nicer, but most importantly, I could lift Z so I wouldn't damage the print! So what retraction settings are you guys using that actually works?
I will also try the "avoid crossing parameters" function to se if that helps. Now it sometimes "scratches" off the first layer because I can't lift Z!
Re: skipping extruder! September 21, 2015 09:54AM |
nah the bed isnt the problem, im talking about lift z when retraction is triggered. so when it travels, it lifts the nozzle a little bit..? or am i wrong here? just completed a print anyways, without retraction... oh my thats gonna need some serious cleaning! gotta try out some more retraction settings! i tried 1mm up to 3 mm retraction, with speed from 20 up to 40... it always made the nozzle clog and extruder started skipping. without retractioin there was barely no skipping, but i just cant get rid of it completely! i guess i just have to try more settings! =)Quote
psneddon
kellef
I don't know what you mean by "can't lift Z" ?? If your scratching the first layer you probably don't have the bed levelled properly - see my previous comments. I was using 4.5mm for a retraction setting and I reduced it to to 3.8mm just in case since my recent bout with a jammed extruder. Seems to work fine either way.
Re: skipping extruder! September 21, 2015 10:03AM |
Re: skipping extruder! September 21, 2015 10:05AM |
Re: skipping extruder! September 21, 2015 10:59AM |
I have! I got it to something like 137.32..... Did this before the new Sd image was avaliable for download! Now i'm running it at 137!Quote
Theolodian
Yeah, have you calibrated extruder steps/mm yet?
Re: skipping extruder! October 12, 2015 03:32PM |
Re: skipping extruder! October 13, 2015 03:48AM |
I removed the fan duct, and I'm now printing the first layer at 215 and the rest at 210! Haven't tried to go up even higher and put it back yet, since I'm facing some other problems right now I'm dealing with!Quote
upsch2000
try increasing print temperature i am printing 220-230 depending on the filament brand
I hope it helped
