Newbie need help March 16, 2016 10:28PM |
Re: Newbie need help March 16, 2016 10:38PM |
Re: Newbie need help March 16, 2016 10:54PM |
Re: Newbie need help March 16, 2016 11:01PM |
Re: Newbie need help March 16, 2016 11:17PM |
Re: Newbie need help March 16, 2016 11:28PM |
Re: Newbie need help March 16, 2016 11:40PM |
Re: Newbie need help March 16, 2016 11:43PM |
Re: Newbie need help March 16, 2016 11:50PM |
Re: Newbie need help March 16, 2016 11:56PM |
; Configuration file for RepRapPro Fisher - delta 3D printer ; Communication and general M111 S0 ; Debug off M550 PRepRapProFisher ; Machine name (can be anything you like) M551 Preprap ; Machine password (used for FTP) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0x43 ; MAC Address ;*** Adjust the IP address and gateway in the following 2 lines to suit your network M552 P172.5.0.30 ; IP address ;M554 P0.0.0.0 ; Gateway M553 P255.255.255.0 ; Netmask M555 P2 ; Set output to look like Marlin G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Axis and motor configuration M569 P0 S0 ; Drive 0 goes forwards M569 P1 S0 ; Drive 1 goes forwards M569 P2 S0 ; Drive 2 goes forwards M569 P3 S0 ; Drive 3 goes forwards M569 P4 S1 ; Drive 4 goes forwards M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high) ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration M665 R81.0 L160.0 B75 H180 ; set delta radius, diagonal rod length, printable radius and homed height M666 X0.0 Y0.0 Z0.0 ; put your endstop adjustments here M92 X87.489 Y87.489 Z87.489 ; Set axis steps/mm M906 X800 Y800 Z800 E1200 ; Set motor currents (mA) M201 X4000 Y4000 Z4000 E4000 ; Accelerations (mm/s^2) M203 X15000 Y15000 Z15000 E3600 ; Maximum speeds (mm/min) M210 Z50 ; Homing feedrate M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute ; Thermistors M305 P1 R4700 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction ; Tool definitions M563 P0 D0 H1 ; Define tool 0 G10 P0 S200 R0 ; Set tool 0 operating and standby temperatures M301 H1 P10 I0.1 D100 W180 M92 E144.0 ; Set extruder steps per mm ;// Z probe and compensation definition ;*** If you have an IR zprobe instead of a switch, change P4 to P1 in the following M558 command M558 P4 X0 Y0 Z0 H4 ; Z probe is a switch and is not used for homing any axes G31 X0 Y0 Z-0.1 P200 ; Set the zprobe height and threshold (put your own values here) ;*** If you are using axis compensation, put the figures in the following command M556 S78 X0 Y0 Z0 ; Axis compensation here
Re: Newbie need help March 17, 2016 12:04AM |
Re: Newbie need help March 17, 2016 12:23AM |
; Configuration file for RepRapPro Fisher - delta 3D printer ; Communication and general M111 S0 ; Debug off M550 PRepRapProFisher ; Machine name (can be anything you like) M551 Preprap ; Machine password (used for FTP) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0x43 ; MAC Address ;*** Adjust the IP address and gateway in the following 2 lines to suit your network M552 P172.5.0.30 ; IP address M553 P255.255.255.0 ; Netmask
Re: Newbie need help March 17, 2016 12:32AM |
Re: Newbie need help March 17, 2016 12:50AM |
Re: Newbie need help March 17, 2016 01:00AM |
Re: Newbie need help March 17, 2016 01:02AM |
Re: Newbie need help March 17, 2016 10:51PM |
Re: Newbie need help March 18, 2016 03:23AM |
Re: Newbie need help March 18, 2016 09:31PM |
Re: Newbie need help March 21, 2016 03:34AM |
Re: Newbie need help March 21, 2016 03:43AM |
