Extruder motor skipping steps March 19, 2016 06:13PM |
Re: Extruder motor skipping steps March 19, 2016 07:09PM |
Re: Extruder motor skipping steps March 20, 2016 05:22AM |
Re: Extruder motor skipping steps March 20, 2016 08:11AM |
dc42
I helped someone else with a similar problem this afternoon. These are the steps we took:
1. The original filament (supplied with the machine I am told) didn't extrude cleanly, but formed a glob attached to the nozzle. We switched to a roll of eSun PLA I had.
2. Dismantled the hot end, unscrewed the nozzle from the heatsink, then screwed it back in but with thermal transfer compound on the nozzle threads this time.
3. Reassembled the hot end without the Bowden tube. Checked that we could push filament through the hot end when it was hot.
4. With the Bowden tube connected, the extruder drive could mostly extrude into free air at 5mm/sec, but occasionally skipped steps. We increased the motor current to 1200mA and the temperature to 210C, then it skipped steps only very occasionally.
5. With power off, swapped the E0 and X motor cables over on the Duet, then tested the printer after sending M569 commands to account for the swap. This was to check that there wasn't a fault on the E0 driver chip.
6. After experiencing a period of time when the extruder motor just vibrated instead of moving, checked all the connections in the extruder motor cable and re-made some.
[EDIT] 6a. Did several cycles of heat to 200C, extrude, cool to 100C, retract filament completely and cut off the end, to remove any foreign matter from the nozzle.
7. Did a 35 minute test print, initially at 1200mA current and 210C. It went well (no skipped steps noticed), so part way through we dropped the temperature to 205C. It continued to print well.
My conclusion is that the Fisher 1.0 extruder is slightly under-powered. It would be better with a higher torque motor or increased gearing. It's OK at 50mm/sec print speed, but can't consistently manage the ~5mm/sec rate needed for 100mm/sec print speed.
Re: Extruder motor skipping steps March 21, 2016 05:27AM |
Re: Extruder motor skipping steps March 21, 2016 06:14AM |
tml
Thanks for the suggestions! I'll start by increasing the current to 1200mA and if it doesn't help, I'll take apart the hot end. When you took the hot end apart, did you find the reason why it might be more difficult for the motor to push the PLA through if the material has been left in the hot end overnight?
Re: Extruder motor skipping steps March 21, 2016 07:45PM |
Re: Extruder motor skipping steps May 12, 2016 08:01AM |
Re: Extruder motor skipping steps May 12, 2016 09:37AM |
Re: Extruder motor skipping steps May 16, 2016 07:38AM |
