Updated firmware and now homing and bed levelling is broken May 22, 2016 02:55PM |
Re: Updated firmware and now homing and bed levelling is broken May 22, 2016 05:06PM |
Re: Updated firmware and now homing and bed levelling is broken May 25, 2016 04:27PM |
dc42
What config.g, homedelta.g and bed.g files are you using? If you updated them when you installed the new firmware, revert to your old ones. I know RepRapPro used to say you should update the SD card contents when you update the firmware, but it's usually not necessary and better not to; except that you should make sure that the files in /www are up to date.
Re: Updated firmware and now homing and bed levelling is broken May 25, 2016 04:49PM |
; bed.g file for RepRapFirmware ; 10 points, 6 factors, probing radius: 75, probe offset (0, 0) G30 P0 X0.00 Y75.00 Z-99999 H0 G30 P1 X64.95 Y37.50 Z-99999 H0 G30 P2 X64.95 Y-37.50 Z-99999 H0 G30 P3 X0.00 Y-75.00 Z-99999 H0 G30 P4 X-64.95 Y-37.50 Z-99999 H0 G30 P5 X-64.95 Y37.50 Z-99999 H0 G30 P6 X0.00 Y37.50 Z-99999 H0 G30 P7 X32.48 Y-18.75 Z-99999 H0 G30 P8 X-32.48 Y-18.75 Z-99999 H0 G30 P9 X0 Y0 Z-99999 S6
Re: Updated firmware and now homing and bed levelling is broken May 25, 2016 05:15PM |
Re: Updated firmware and now homing and bed levelling is broken May 25, 2016 06:25PM |
Re: Updated firmware and now homing and bed levelling is broken May 25, 2016 06:33PM |
Re: Updated firmware and now homing and bed levelling is broken May 25, 2016 07:49PM |
Re: Updated firmware and now homing and bed levelling is broken May 25, 2016 07:57PM |
Re: Updated firmware and now homing and bed levelling is broken May 25, 2016 08:16PM |
Re: Updated firmware and now homing and bed levelling is broken May 25, 2016 08:32PM |
Re: Updated firmware and now homing and bed levelling is broken May 25, 2016 08:45PM |
Re: Updated firmware and now homing and bed levelling is broken May 25, 2016 08:50PM |
Re: Updated firmware and now homing and bed levelling is broken May 25, 2016 08:57PM |
Re: Updated firmware and now homing and bed levelling is broken May 25, 2016 09:00PM |
Re: Updated firmware and now homing and bed levelling is broken May 25, 2016 09:03PM |
Re: Updated firmware and now homing and bed levelling is broken May 25, 2016 09:12PM |
Re: Updated firmware and now homing and bed levelling is broken May 25, 2016 09:14PM |
Re: Updated firmware and now homing and bed levelling is broken May 25, 2016 09:18PM |
Re: Updated firmware and now homing and bed levelling is broken May 26, 2016 05:29AM |
Re: Updated firmware and now homing and bed levelling is broken May 26, 2016 04:35PM |
Re: Updated firmware and now homing and bed levelling is broken May 26, 2016 06:14PM |
Re: Updated firmware and now homing and bed levelling is broken May 26, 2016 06:26PM |
Re: Updated firmware and now homing and bed levelling is broken May 26, 2016 06:40PM |
Re: Updated firmware and now homing and bed levelling is broken May 26, 2016 06:46PM |
Re: Updated firmware and now homing and bed levelling is broken May 26, 2016 06:47PM |
Re: Updated firmware and now homing and bed levelling is broken May 26, 2016 06:56PM |
dc42
It should be possible to find a set of probe points and corresponding H values that work well on most Fishers, or at least provide a good starting point. I don't have a Fisher, so I can't provide that.
One thing I don't like about the Fisher design is the way that the carriages slide pas the microswitches to activate them. It appears to me that the trigger point will depend a lot on the shape of the spring arm on the microswitch. On most delta printers, the carriages drive into the microswitches - but this reduces the available build height by the height of the microswitch.
Re: Updated firmware and now homing and bed levelling is broken May 26, 2016 08:39PM |
Re: Updated firmware and now homing and bed levelling is broken May 27, 2016 02:34AM |
Re: Updated firmware and now homing and bed levelling is broken May 27, 2016 03:17AM |
