SC8UU & SC10UU linear bearing blocks
September 10, 2012 05:17AM
Anyone here used these on a reprap? [www.aliexpress.com] looks like an easy carriage build and they aren't all that expensive.
Might have to design some x-ends to use them too.
_________________________________________________________________________________________
Richmond, New Zealand
Thingiverse ~ YouTube
Re: SC8UU & SC10UU linear bearing blocks
September 10, 2012 03:45PM
At $2.75/piece (USD, qty 12) including shipping, they are a bit more expensive than Chinese LM8UU's. There's no reason you couldn't use them, especially for the Y axis. It would make for an easy Y axis build, and could work well with the Z axis too. The only issue with the X axis carriage is that the SC8UU's are fairly wide, which is going to limit space for the hotend. This may not be an issue with narrower hotends such as the J-Head, but could be problematic for the Acrol.hu type hotends, unless you made the carriage wider.
Edited 1 time(s). Last edit at 09/10/2012 03:45PM by NewPerfection.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
September 10, 2012 03:54PM
Yes I did eventually look them up on Aliexpress too and have saved a few options. They do look easy for the Y-axis but I'll probably stick with LM10UU's for the Z and LM8UU's for the X. Just wondering if anyone had used them before.
May 29, 2013 10:14AM
I am interested in SC10UU bearings...
Is there an advantage to using these bearings with an Aluminium framed i3 ?
May 29, 2013 05:55PM
I'm using graphite impregnated nylon bushes at the mo which have been successful. I do, however, like the idea of going the "LM" route but hear so many conflicting reports about them - dunno what to do to be honest confused smiley
May 29, 2013 08:06PM
I have lm8uu
They are louder than bushes, as you have a number ball bearing moving in them. And you have to lubricate them.
Lm8uu also seem to have more movement in them. So its good if your machine is a fraction out, but bad as belt ringing is transfered to your print (this on is just my own thoughts of what seem to be happening.)
August 25, 2013 04:20AM
I've got some linear (ball) bearings on my delta at the moment and they are the noisest part of the machine by far. Go plastic!
