Ladies and gents,
Probably I could have done more googling but well...
I do have a end.gcode set in my slicer so when print finishes it homes XY and drops Z down but that obviously only works if print goes to the end (aka successful print, or unsuccessful unattended).
But very annoyingly when you kill the print from the LCD panel (printing from SD) it just instantly stops all the movement and you need to manually move hotend aside or manually rotate leadscrew for Z to go down.
Can't figure out where I can set XY homing on killed print. If that's even possible...
Thanks.
Kris
