I've got a really unusual issue with a corexy i've just finished. II'm using an mks gen 1.4 that is known good as i used in another machine, watterott tmc2130's wired up correctly, m122 shows good results. Full graphic smart controller (I remapped the CS pins to get them both working at the same time). The printer boots, my software controlled LED's work fine, and the axes' sort of work. here's my issue. If i move the axes around through either pronterface, simplify or the controller, it works for a bit, then the entire controller locks up and the serial activity LED's go mental, even when not connected to my laptop. Pressing the estop on the controller doesn't fix it, neither does sending a reset command over the PC. I have to unplug the entire machine from the wall and my pc to stop it. any ideas on how to fix it?
