Endstop issue February 15, 2019 04:11AM |
#define X_STOP_PIN 31 #define Y_STOP_PIN 30 #define Z_STOP_PIN 29And then, in Configuration.h
#define USE_XMIN_PLUG #define USE_YMIN_PLUG #define USE_ZMIN_PLUG //#define USE_XMAX_PLUG //#define USE_YMAX_PLUG //#define USE_ZMAX_PLUG // Enable pullup for all endstops to prevent a floating state //#define ENDSTOPPULLUPS //THERE ARE EXTERNAL PULLUPS ALREADYSince I only have min endstops and I've used external 10k pullup resistor.
PIN: 29 Port: A5 Z_MIN_PIN protected . Z_STOP_PIN protected PIN: 30 Port: A6 Y_MIN_PIN protected . Y_STOP_PIN protected PIN: 31 Port: A7 X_MIN_PIN protected . X_STOP_PIN protected
Re: Endstop issue February 15, 2019 04:55AM |
Admin Registered: 13 years ago Posts: 7,002 |
Re: Endstop issue February 15, 2019 05:43AM |
Re: Endstop issue February 15, 2019 06:39AM |
Re: Endstop issue February 15, 2019 07:26AM |
Re: Endstop issue February 15, 2019 08:24AM |
Re: Endstop issue February 15, 2019 09:15AM |
/** ATMega644 * * +---\/---+ * (D 0) PB0 1| |40 PA0 (AI 0 / D31) * (D 1) PB1 2| |39 PA1 (AI 1 / D30) * INT2 (D 2) PB2 3| |38 PA2 (AI 2 / D29) * PWM (D 3) PB3 4| |37 PA3 (AI 3 / D28) * PWM (D 4) PB4 5| |36 PA4 (AI 4 / D27) * MOSI (D 5) PB5 6| |35 PA5 (AI 5 / D26) * MISO (D 6) PB6 7| |34 PA6 (AI 6 / D25) * SCK (D 7) PB7 8| |33 PA7 (AI 7 / D24) * RST 9| |32 AREF * VCC 10| |31 GND * GND 11| |30 AVCC * XTAL2 12| |29 PC7 (D 23) * XTAL1 13| |28 PC6 (D 22) * RX0 (D 8) PD0 14| |27 PC5 (D 21) TDI * TX0 (D 9) PD1 15| |26 PC4 (D 20) TDO * INT0 RX1 (D 10) PD2 16| |25 PC3 (D 19) TMS * INT1 TX1 (D 11) PD3 17| |24 PC2 (D 18) TCK * PWM (D 12) PD4 18| |23 PC1 (D 17) SDA * PWM (D 13) PD5 19| |22 PC0 (D 16) SCL * PWM (D 14) PD6 20| |21 PD7 (D 15) PWM * +--------+ */
Re: Endstop issue February 15, 2019 09:23AM |
Re: Endstop issue February 15, 2019 09:34AM |
Re: Endstop issue February 15, 2019 09:39AM |
Re: Endstop issue February 15, 2019 11:03AM |
