Welcome!
Log In
Create A New Profile
Home
Firmware Folder
Firmware - Marlin
> Topic
Is there a Temp Offset parameter buried someplace in Bugfix 2.0?
Posted by
WatIDo
Forum List
Message List
New Topic
WatIDo
February 16, 2019 04:19PM
My Thermistors report one Temp but regular and IR Thermometers report another. It's pretty common with most Temp Controllers to be able to calibrate/fine tune your Temp sensor with a +/- offset degree value. DOes this exist with Marlin?
Thanks in advance for any advice!
Reply
Roberts_Clif
Re: Is there a Temp Offset parameter buried someplace in Bugfix 2.0?
February 16, 2019 05:11PM
I would ask you what thermister you are using and the setting you used in Marlin for your Nozzle and bed.
Reply
WatIDo
February 17, 2019 06:39PM
Thanks for the reply!!! I am using FYSETC, HT-NTC100K Thermistors on both Bed & Hot End. Setting in FW is 1 for both
Reply
Dust
February 17, 2019 07:56PM
Admin
Thermistor responses are not linear, An offset would correct the temperature at one particular temperature and make it incorrect everywhere else
You need to select the correct temperature table for you're device. Google tells me this is 13 not 1
Reply
WatIDo
February 17, 2019 10:29PM
Thanks Dust!
Reply
Newer Topic
Older Topic
Print View
RSS
