Auto level sensor proximity
Posted by manarooo
March 16, 2019 10:30AM
Hi, I want to use this sensor pl-P802 to fix the bed but I do not know how to use it so that the bed will automatically work. I use Marlin2.0
I want to run the sensor as it works in the Repetier program but I can not connect the sensor to z max endstop
I want him to check the bed automatically
Re: Auto level sensor proximity
March 16, 2019 11:25AM
Let me see if I have this right. You want to use a P802 Three - wire inductive proximity switch NPN sensing distance 8MM.
Correct.
The wiring is the same as the SN04N
Color - Label - Ramps Pin number
Brown = Power = 3
Blue = Ground = 2
Black = Sense = 1
Hictop Controller Wiring
[buyrvu.blogspot.com]
March 16, 2019 01:46PM
Yes true wire as in picture
open | download - IMG-20190316-WA0002.jpg (177.6 KB)
