not that I have seen..
only thing close is the macros
#define SET_INPUT(IO) _SET_MODE(IO, INPUT) /*!< Input Floating Mode */
#define SET_INPUT_PULLUP(IO) _SET_MODE(IO, INPUT_PULLUP) /*!< Input with Pull-up activation */
#define SET_INPUT_PULLDOWN(IO) _SET_MODE(IO, INPUT_PULLDOWN) /*!< Input with Pull-down activation */
#define SET_OUTPUT(IO) OUT_WRITE(IO, LOW)
#define SET_PWM(IO) pinMode(IO, PWM)
So easy enough to add your own but using OUTPUT_OPEN_DRAIN or PWM_OPEN_DRAIN
