Marlin 1.1.9 Full Reprap Graphic not showing correctly August 18, 2018 04:41PM |
Re: Marlin 1.1.9 Full Reprap Graphic not showing correctly August 18, 2018 05:31PM |
Re: Marlin 1.1.9 Full Reprap Graphic not showing correctly August 19, 2018 02:15AM |
#if ENABLED(U8GLIB_ST7920) /** * ST7920-based LCDs can emulate a 16 x 4 character display using * the ST7920 character-generator for very fast screen updates. * Enable LIGHTWEIGHT_UI to use this special display mode. * * Since LIGHTWEIGHT_UI has limited space, the position and status * message occupy the same line. Set STATUS_EXPIRE_SECONDS to the * length of time to display the status message before clearing. * * Set STATUS_EXPIRE_SECONDS to zero to never clear the status. * This will prevent position updates from being displayed. */ //#define LIGHTWEIGHT_UI #if ENABLED(LIGHTWEIGHT_UI) #define STATUS_EXPIRE_SECONDS 20 #endif #endif #endif // DOGLCD
Re: Marlin 1.1.9 Full Reprap Graphic not showing correctly August 19, 2018 07:23AM |
Re: Marlin 1.1.9 Full Reprap Graphic not showing correctly August 19, 2018 10:28AM |
Re: Marlin 1.1.9 Full Reprap Graphic not showing correctly August 19, 2018 11:20AM |
Re: Marlin 1.1.9 Full Reprap Graphic not showing correctly August 19, 2018 12:13PM |
Re: Marlin 1.1.9 Full Reprap Graphic not showing correctly August 19, 2018 01:24PM |
Re: Marlin 1.1.9 Full Reprap Graphic not showing correctly August 19, 2018 02:55PM |
Re: Marlin 1.1.9 Full Reprap Graphic not showing correctly August 19, 2018 05:00PM |
Re: Marlin 1.1.9 Full Reprap Graphic not showing correctly August 20, 2018 03:37PM |
Re: Marlin 1.1.9 Full Reprap Graphic not showing correctly October 20, 2019 12:43PM |
