Hi there, but
I cannot get Marlin V.2 to compile in VSCODE and Atom. One of my older versions of Marlin bugfix 2.0 do compile with no problems. Any newer versions all give me the error below. I have uninstalled the NXP platform and let it download the latest but it did not work. Can anyone give me pointers on what to try next. The platform.io file in the older version that compiles is precisely the same as the one in the new version that is not compiling. Am I missing something here?
The output on my build:
> Executing task: C:\Users\scrat\.platformio\penv\Scripts\platformio.exe run <
Can not remove temporary directory `d:\Nic\Prusa I3 3d printer\Firmware\Current - HyperCube\MarlinFirmware\.pioenvs`. Please remove it manually to avoid build issues
Processing LPC1768 (platform: [
github.com]; framework: arduino; board: nxp_lpc1768)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: [
docs.platformio.org]
PLATFORM: NXP Arduino LPC176x 0.1.0 > NXP LPC1768
HARDWARE: LPC1768 100MHz, 31.97KB RAM, 464KB Flash
DEBUG: Current (cmsis-dap) On-board (cmsis-dap) External (blackmagic, jlink)
PACKAGES: framework-arduino-lpc176x 0.1.3, toolchain-gccarmnoneeabi 1.80201.190214 (8.2.1)
Converting Marlin.ino
LDF: Library Dependency Finder -> [
bit.ly]
LDF Modes: Finder ~ off, Compatibility ~ strict
Found 5 compatible libraries
Scanning dependencies...
Dependency Graph
|-- 1.0.0
|-- 1.0.0
|-- 0.4
|-- 0.6.1
|-- 1.2.4
Building in release mode
upload disk: E:
Compiling .pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\DebugMonitor.cpp.o
Compiling .pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\HAL.cpp.o
Compiling .pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\HAL_SPI.cpp.o
Compiling .pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\main.cpp.o
Compiling .pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\persistent_store_flash.cpp.o
Compiling .pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\persistent_store_sdcard.cpp.o
Compiling .pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\timers.cpp.o
Compiling .pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\u8g\u8g_com_HAL_LPC1768_hw_spi.cpp.o
Compiling .pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\u8g\u8g_com_HAL_LPC1768_ssd_hw_i2c.cpp.o
Compiling .pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\u8g\u8g_com_HAL_LPC1768_st7920_hw_spi.cpp.o
Compiling .pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\u8g\u8g_com_HAL_LPC1768_st7920_sw_spi.cpp.o
Compiling .pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\watchdog.cpp.o
In file included from Marlin\src\HAL\HAL_LPC1768\../../core/../inc/MarlinConfig.h:39,
from Marlin\src\HAL\HAL_LPC1768\../../core/serial.h:24,
from Marlin\src\HAL\HAL_LPC1768\DebugMonitor.cpp:26:
Marlin\src\HAL\HAL_LPC1768\../../core/../inc/../HAL/HAL_LPC1768/inc/SanityCheck.h:25:4: error: #error "nxplpc-arduino-lpc176x package is out of date, Please update the PlatformIO platforms, frameworks and libraries. You may need to remove the platform and let it reinstall automatically."
Marlin\src\HAL\HAL_LPC1768\../../core/../inc/../HAL/HAL_LPC1768/inc/SanityCheck.h:28:4: error: #error "framework-arduino-lpc176x package is out of date, Please update the PlatformIO platforms, frameworks and libraries."
Marlin\src\HAL\HAL_LPC1768\../../core/../inc/../HAL/HAL_LPC1768/inc/SanityCheck.h:36:4: error: #error "TEMP_BED_PIN must be defined using the Pn_nn or Pn_nn_An format. (See the included pins files)."
In file included from Marlin\src\HAL\HAL_LPC1768\../../inc/MarlinConfig.h:39,
from Marlin\src\HAL\HAL_LPC1768\HAL.cpp:25:
Marlin\src\HAL\HAL_LPC1768\../../inc/../HAL/HAL_LPC1768/inc/SanityCheck.h:25:4: error: #error "nxplpc-arduino-lpc176x package is out of date, Please update the PlatformIO platforms, frameworks and libraries. You may need to remove the platform and let it reinstall automatically."
Marlin\src\HAL\HAL_LPC1768\../../inc/../HAL/HAL_LPC1768/inc/SanityCheck.h:28:4: error: #error "framework-arduino-lpc176x package is out of date, Please update the PlatformIO platforms, frameworks and libraries."
Marlin\src\HAL\HAL_LPC1768\../../inc/../HAL/HAL_LPC1768/inc/SanityCheck.h:36:4: error: #error "TEMP_BED_PIN must be defined using the Pn_nn or Pn_nn_An format. (See
In file included from .piolibdeps\LPC1768\U8glib-HAL_ID1932\src/U8glib.h:47,
from Marlin\src\HAL\HAL_LPC1768\u8g\u8g_com_HAL_LPC1768_hw_spi.cpp:62:
.piolibdeps\LPC1768\U8glib-HAL_ID1932\src/clib/u8g.h:658:12: fatal error: HAL_LCD_defines.h: No such file or directory
* Looking for HAL_LCD_defines.h dependency? Check our library registry!
* CLI > platformio lib search "header:HAL_LCD_defines.h"
* Web > [
platformio.org]
#include
compilation terminated.
from Marlin\src\HAL\HAL_LPC1768\HAL_SPI.cpp:51:
*** [.pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\u8g\u8g_com_HAL_LPC1768_hw_spi.cpp.o] Error 1
from Marlin\src\HAL\HAL_LPC1768\u8g\u8g_com_HAL_LPC1768_ssd_hw_i2c.cpp:82:
* Web > [
platformio.org]
#include
from Marlin\src\HAL\HAL_LPC1768\u8g\u8g_com_HAL_LPC1768_st7920_sw_spi.cpp:62:
* Web > [
platformio.org]
#include
*** [.pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\u8g\u8g_com_HAL_LPC1768_ssd_hw_i2c.cpp.o] Error 1
from Marlin\src\HAL\HAL_LPC1768\u8g\u8g_com_HAL_LPC1768_st7920_hw_spi.cpp:62:
* Web > [
platformio.org]
#include
*** [.pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\u8g\u8g_com_HAL_LPC1768_st7920_sw_spi.cpp.o] Error 1
*** [.pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\u8g\u8g_com_HAL_LPC1768_st7920_hw_spi.cpp.o] Error 1
In file included from Marlin\src\HAL\HAL_LPC1768\../../sd/../inc/MarlinConfig.h:39,
from Marlin\src\HAL\HAL_LPC1768\../../sd/cardreader.h:24,
from Marlin\src\HAL\HAL_LPC1768\main.cpp:38:
Marlin\src\HAL\HAL_LPC1768\../../sd/../inc/../HAL/HAL_LPC1768/inc/SanityCheck.h:25:4: error: #error "nxplpc-arduino-lpc176x package is out of date, Please update the PlatformIO platforms, frameworks and libraries. You may need to remove the platform and let it reinstall automatically."
Marlin\src\HAL\HAL_LPC1768\../../sd/../inc/../HAL/HAL_LPC1768/inc/SanityCheck.h:28:4: error: #error "framework-arduino-lpc176x package is out of date, Please update
Marlin\src\HAL\HAL_LPC1768\../../sd/../inc/../HAL/HAL_LPC1768/inc/SanityCheck.h:36:4: error: #error "TEMP_BED_PIN must be defined using the Pn_nn or Pn_nn_An format. (See the included pins files)."
from Marlin\src\HAL\HAL_LPC1768\persistent_store_flash.cpp:44:
from Marlin\src\HAL\HAL_LPC1768\persistent_store_sdcard.cpp:29:
from Marlin\src\HAL\HAL_LPC1768\timers.cpp:31:
from Marlin\src\HAL\HAL_LPC1768\watchdog.cpp:25:
In file included from Marlin\src\HAL\HAL_LPC1768\../../core/../inc/../HAL/HAL.h:26,
from Marlin\src\HAL\HAL_LPC1768\../../core/../inc/MarlinConfig.h:30,
Marlin\src\HAL\HAL_LPC1768\../../core/../inc/../HAL/./HAL_LPC1768/HAL.h: In function 'void HAL_start_adc(pin_t)':
Marlin\src\HAL\HAL_LPC1768\../../core/../inc/../HAL/./HAL_LPC1768/HAL.h:140:34: error: 'read' is not a member of 'FilteredADC' {aka 'LPC176x::ADC<2, 23>'}
HAL_adc_reading = FilteredADC::read(pin) >> (16 - HAL_ADC_RESOLUTION); // returns 16bit value, reduce to required bits
Marlin\src\HAL\HAL_LPC1768\../../core/../inc/../HAL/./HAL_LPC1768/HAL.h: At global scope:
Marlin\src\HAL\HAL_LPC1768\../../core/../inc/../HAL/./HAL_LPC1768/HAL.h:153:16: error: redefinition of 'constexpr bool VALID_PIN(pin_t)'
constexpr bool VALID_PIN(const pin_t pin) {
In file included from C:\users\scrat\.platformio\packages\framework-arduino-lpc176x\cores\arduino/Arduino.h:34,
from Marlin\src\HAL\HAL_LPC1768\../../core/../inc/../HAL/./HAL_LPC1768/../shared/Marduino.h:36,
from Marlin\src\HAL\HAL_LPC1768\../../core/../inc/../HAL/./HAL_LPC1768/HAL.h:39,
C:\users\scrat\.platformio\packages\framework-arduino-lpc176x\cores\arduino/pinmapping.h:240:16: note: 'constexpr bool VALID_PIN(pin_t)' previously defined here
compilation terminated due to -fmax-errors=5.
In file included from Marlin\src\HAL\HAL_LPC1768\../../inc/../HAL/HAL.h:26,
from Marlin\src\HAL\HAL_LPC1768\../../inc/MarlinConfig.h:30,
Marlin\src\HAL\HAL_LPC1768\../../inc/../HAL/./HAL_LPC1768/HAL.h: In function 'void HAL_start_adc(pin_t)':
Marlin\src\HAL\HAL_LPC1768\../../inc/../HAL/./HAL_LPC1768/HAL.h:140:34: error: 'read' is not a member of 'FilteredADC' {aka 'LPC176x::ADC<2, 23>'}
Marlin\src\HAL\HAL_LPC1768\../../inc/../HAL/./HAL_LPC1768/HAL.h: At global scope:
Marlin\src\HAL\HAL_LPC1768\../../inc/../HAL/./HAL_LPC1768/HAL.h:153:16: error: redefinition of 'constexpr bool VALID_PIN(pin_t)'
from Marlin\src\HAL\HAL_LPC1768\../../inc/../HAL/./HAL_LPC1768/../shared/Marduino.h:36,
from Marlin\src\HAL\HAL_LPC1768\../../inc/../HAL/./HAL_LPC1768/HAL.h:39,
*** [.pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\DebugMonitor.cpp.o] Error 1
*** [.pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\HAL.cpp.o] Error 1
In file included from Marlin\src\HAL\HAL_LPC1768\../../sd/../inc/../HAL/HAL.h:26,
from Marlin\src\HAL\HAL_LPC1768\../../sd/../inc/MarlinConfig.h:30,
Marlin\src\HAL\HAL_LPC1768\../../sd/../inc/../HAL/./HAL_LPC1768/HAL.h: In function 'void HAL_start_adc(pin_t)':
Marlin\src\HAL\HAL_LPC1768\../../sd/../inc/../HAL/./HAL_LPC1768/HAL.h:140:34: error: 'read' is not a member of 'FilteredADC' {aka 'LPC176x::ADC<2, 23>'}
Marlin\src\HAL\HAL_LPC1768\../../sd/../inc/../HAL/./HAL_LPC1768/HAL.h: At global scope:
Marlin\src\HAL\HAL_LPC1768\../../sd/../inc/../HAL/./HAL_LPC1768/HAL.h:153:16: error: redefinition of 'constexpr bool VALID_PIN(pin_t)'
from C:\users\scrat\.platformio\packages\framework-arduino-lpc176x\cores\arduino/CDCSerial.h:34,
from Marlin\src\HAL\HAL_LPC1768\main.cpp:31:
*** [.pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\HAL_SPI.cpp.o] Error 1
*** [.pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\main.cpp.o] Error 1
*** [.pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\persistent_store_flash.cpp.o] Error 1
*** [.pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\persistent_store_sdcard.cpp.o] Error 1
*** [.pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\timers.cpp.o] Error 1
*** [.pioenvs\LPC1768\src\src\HAL\HAL_LPC1768\watchdog.cpp.o] Error 1
==================================================================== [FAILED] Took 2.39 seconds ====================================================================
Environment Status Duration
megaatmega2560 IGNORED
megaatmega1280 IGNORED
at90usb1286_cdc IGNORED
at90usb1286_dfu IGNORED
DUE IGNORED
DUE_USB IGNORED
DUE_debug IGNORED
LPC1768 FAILED 00:00:02.392
LPC1769 IGNORED
melzi IGNORED
melzi_optiboot IGNORED
rambo IGNORED
sanguino_atmega644p IGNORED
sanguino_atmega1284p IGNORED
STM32F1 IGNORED
STM32F4 IGNORED
ARMED IGNORED
mks_robin IGNORED
black_stm32f407ve IGNORED
teensy35 IGNORED
malyanm200 IGNORED
esp32 IGNORED
fysetc_f6_13 IGNORED
linux_native IGNORED
============================================================== 1 failed, 0 succeeded in 00:00:02.392 ==============================================================
The terminal process terminated with exit code: 1
Terminal will be reused by tasks, press any key to close it.
Regards
Nic
Edited 1 time(s). Last edit at 12/01/2019 03:19AM by scratchbuild52@gmail.com.
