Hello,
My name is Álvaro, from Spain. I have a Tronxy X3, converted to Ramps 1.6 with Marlin 2.0 in order to use dual extruder configuration. I have had some problems solved with time and internet searchs. However, I can't solve a pair of problems.
First problem:
Still don't have automatic bed level sensor, so I've tried to configure Marlin to perform a manual bed leveling through the LCD. Uncommenting:
#define PROBE_MANUALLY
#define AUTO_BED_LEVELING_BILINEAR
#define LCD_BED_LEVELING
#define LEVEL_BED_CORNERS
When I select bed leveling in the menu, it only homes the printer, and returns (inmediatly when starts homing) to the main info screen
Second problem:
Without the leveling function, I perform a totally manual height adjustment, homing the printer, and using bed screws. When it starts printing, it goes a bit higher than expected, and the material doesn't sticks into the bed. I'm using simplest endstops, without condensers or resistors, in normally closed configuration for the Z, and normally opened for the X and Y. Could this behaviour due to a noisy switch?
Thanks in advance
Edited 1 time(s). Last edit at 04/22/2020 06:58AM by ammm84.
