TMC2130 Extremely loud April 27, 2019 09:12AM |
14:46:10.580 : X Y Z 14:46:10.581 : Enabled false false false 14:46:10.581 : Set current 1000 1000 1000 14:46:10.583 : RMS current 994 994 994 14:46:10.586 : MAX current 1402 1402 1402 14:46:10.587 : Run current 17/31 17/31 17/31 14:46:10.588 : Hold current 8/31 8/31 8/31 14:46:10.590 : CS actual 8/31 8/31 8/31 14:46:10.590 : PWM scale 1 1 1 14:46:10.591 : vsense 0=.325 0=.325 0=.325 14:46:10.593 : stealthChop true true true 14:46:10.593 : msteps 16 16 16 14:46:10.595 : tstep 1048575 1048575 1048575 14:46:10.596 : pwm 14:46:10.596 : threshold 0 0 0 14:46:10.597 : [mm/s] - - - 14:46:10.598 : OT prewarn false false false 14:46:10.599 : OT prewarn has 14:46:10.600 : been triggered false false false 14:46:10.600 : off time 5 5 5 14:46:10.602 : blank time 24 24 24 14:46:10.602 : hysteresis 14:46:10.603 : -end 2 2 2 14:46:10.603 : -start 3 3 3 14:46:10.605 : Stallguard thrs 0 0 0 14:46:10.605 : DRVSTATUS X Y Z 14:46:10.606 : stallguard 14:46:10.606 : sg_result 0 0 0 14:46:10.608 : fsactive 14:46:10.608 : stst X X X 14:46:10.608 : olb 14:46:10.609 : ola 14:46:10.609 : s2gb 14:46:10.609 : s2ga 14:46:10.611 : otpw 14:46:10.611 : ot 14:46:10.612 : Driver registers: X = 0x80:08:00:00 14:46:10.612 : Y = 0x80:08:00:00 14:46:10.614 : Z = 0x80:08:00:00
#define X_DRIVER_TYPE TMC2130 #define Y_DRIVER_TYPE TMC2130 #define Z_DRIVER_TYPE TMC2130 #define X2_DRIVER_TYPE A4988 #define Y2_DRIVER_TYPE A4988 #define Z2_DRIVER_TYPE A4988 #define E0_DRIVER_TYPE A4988 #define E1_DRIVER_TYPE A4988 #define E2_DRIVER_TYPE A4988 #define E3_DRIVER_TYPE A4988 #define E4_DRIVER_TYPE A4988TMC2130 config:
#if HAS_TRINAMIC #define R_SENSE 0.11 // R_sense resistor for SilentStepStick2130 #define HOLD_MULTIPLIER 0.5 // Scales down the holding current from run current #define INTERPOLATE true // Interpolate X/Y/Z_MICROSTEPS to 256 #define X_CURRENT 1000 // rms current in mA. Multiply by 1.41 for peak current. #define X_MICROSTEPS 16 // 0..256 #define Y_CURRENT 1000 #define Y_MICROSTEPS 16 #define Z_CURRENT 1000 #define Z_MICROSTEPS 16 #define X2_CURRENT 800 #define X2_MICROSTEPS 16 #define Y2_CURRENT 800 #define Y2_MICROSTEPS 16 #define Z2_CURRENT 800 #define Z2_MICROSTEPS 16 #define E0_CURRENT 800 #define E0_MICROSTEPS 16 #define E1_CURRENT 800 #define E1_MICROSTEPS 16 #define E2_CURRENT 800 #define E2_MICROSTEPS 16 #define E3_CURRENT 800 #define E3_MICROSTEPS 16 #define E4_CURRENT 800 #define E4_MICROSTEPS 16 /** * Use software SPI for TMC2130. * The default SW SPI pins are defined the respective pins files, * but you can override or define them here. */ //#define TMC_USE_SW_SPI //#define TMC_SW_MOSI -1 //#define TMC_SW_MISO -1 //#define TMC_SW_SCK -1 /** * Use Trinamic's ultra quiet stepping mode. * When disabled, Marlin will use spreadCycle stepping mode. */ #define STEALTHCHOP /** * Monitor Trinamic TMC2130 and TMC2208 drivers for error conditions, * like overtemperature and short to ground. TMC2208 requires hardware serial. * In the case of overtemperature Marlin can decrease the driver current until error condition clears. * Other detected conditions can be used to stop the current print. * Relevant g-codes: * M906 - Set or get motor current in milliamps using axis codes X, Y, Z, E. Report values if no axis codes given. * M911 - Report stepper driver overtemperature pre-warn condition. * M912 - Clear stepper driver overtemperature pre-warn condition flag. * M122 S0/1 - Report driver parameters (Requires TMC_DEBUG) */ #define MONITOR_DRIVER_STATUS #if ENABLED(MONITOR_DRIVER_STATUS) #define CURRENT_STEP_DOWN 50 // [mA] #define REPORT_CURRENT_CHANGE #define STOP_ON_ERROR #endif /** * The driver will switch to spreadCycle when stepper speed is over HYBRID_THRESHOLD. * This mode allows for faster movements at the expense of higher noise levels. * STEALTHCHOP needs to be enabled. * M913 X/Y/Z/E to live tune the setting */ //#define HYBRID_THRESHOLD #define X_HYBRID_THRESHOLD 100 // [mm/s] #define X2_HYBRID_THRESHOLD 100 #define Y_HYBRID_THRESHOLD 100 #define Y2_HYBRID_THRESHOLD 100 #define Z_HYBRID_THRESHOLD 3 #define Z2_HYBRID_THRESHOLD 3 #define E0_HYBRID_THRESHOLD 30 #define E1_HYBRID_THRESHOLD 30 #define E2_HYBRID_THRESHOLD 30 #define E3_HYBRID_THRESHOLD 30 #define E4_HYBRID_THRESHOLD 30 /** * Use stallGuard2 to sense an obstacle and trigger an endstop. * You need to place a wire from the driver's DIAG1 pin to the X/Y endstop pin. * X, Y, and Z homing will always be done in spreadCycle mode. * * X/Y/Z_HOMING_SENSITIVITY is used for tuning the trigger sensitivity. * Higher values make the system LESS sensitive. * Lower value make the system MORE sensitive. * Too low values can lead to false positives, while too high values will collide the axis without triggering. * It is advised to set X/Y/Z_HOME_BUMP_MM to 0. * M914 X/Y/Z to live tune the setting */ //#define SENSORLESS_HOMING // TMC2130 only #if ENABLED(SENSORLESS_HOMING) #define X_HOMING_SENSITIVITY 8 #define Y_HOMING_SENSITIVITY 8 #define Z_HOMING_SENSITIVITY 8 #endif /** * Enable M122 debugging command for TMC stepper drivers. * M122 S0/1 will enable continous reporting. */ #define TMC_DEBUG /** * M915 Z Axis Calibration * * - Adjust Z stepper current, * - Drive the Z axis to its physical maximum, and * - Home Z to account for the lost steps. * * Use M915 Snn to specify the current. * Use M925 Znn to add extra Z height to Z_MAX_POS. */ //#define TMC_Z_CALIBRATION #if ENABLED(TMC_Z_CALIBRATION) #define CALIBRATION_CURRENT 250 #define CALIBRATION_EXTRA_HEIGHT 10 #endif /** * You can set your own advanced settings by filling in predefined functions. * A list of available functions can be found on the library github page * [github.com] * [github.com] * * Example: * #define TMC_ADV() { \ * stepperX.diag0_temp_prewarn(1); \ * stepperY.interpolate(0); \ * } */ #define TMC_ADV() { } #endif // TMC2130 || TMC2208
Re: TMC2130 Extremely loud April 27, 2019 10:27AM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: TMC2130 Extremely loud April 27, 2019 10:43AM |
Re: TMC2130 Extremely loud April 27, 2019 10:50AM |
Re: TMC2130 Extremely loud April 27, 2019 11:16AM |
I know that 24v is better, but that does not explain why it is so freaking loud. It is way louder than A4988, which does not make any sense at all.Quote
Pippy
24V for the motors is MUCH better.
But you might want to use hybrid threshold for the TMC2130's to work in both modes (speed dependent), but that will need you to discover usable threshold values for switching between stealthchop and spreadcycle.
Doesn't a delta need a 32-bit board for the stepping and kinematic calculations etc to keep up ?
Re: TMC2130 Extremely loud March 28, 2020 03:36AM |
Re: TMC2130 Extremely loud March 28, 2020 01:06PM |
{ off_time[1..15], hysteresis_end[-3..12], hysteresis_start[1..8] }You can calculate it using "TMC2130_Calculations.xlsx" with your Motor Parameters (Coil inductance and resistance). This can be found here: Link (GitHub)
#define CHOPPER_TEST_TMC2130_24V { 5, -2, 1}And then use parameter set in Configuration_adv.h.
#define CHOPPER_TIMING CHOPPER_TEST_TMC2130_24V //42HS19 2A @24VMaybe this will help. ... please let us know
Re: TMC2130 Extremely loud April 06, 2020 09:56AM |
Re: TMC2130 Extremely loud April 06, 2020 09:58AM |
AndY_1981
Did you tried to calculate the right values for the spreadCycle chopper parameters in Configuration_adv.h?
Maybe chopper freq. is to low.
Re: TMC2130 Extremely loud April 08, 2020 03:10PM |
Re: TMC2130 Extremely loud April 08, 2020 10:40PM |
AndY_1981
@printer_dave
I try to use 2.0.5.2 ... maybe your Firmware version is to old ... at 2.0.5.2 you can find it in configuration_adv.h at line 2253
For your Steppers it should look like this in the "tmc_util.h" (if you use 16MHz CPU):
#define CHOPPER_xxx_12V { 5, -3, 1}
#define CHOPPER_TIMING CHOPPER_DEFAULT_12V
#define CHOPPER_DEFAULT_12V { 3, -1, 1 }and changed it to
#define CHOPPER_DEFAULT_12V { 5, -3, 1 }, but I can't hear a difference in sound.
Re: TMC2130 Extremely loud April 17, 2020 02:14PM |
Re: TMC2130 Extremely loud May 10, 2020 09:35AM |
Re: TMC2130 Extremely loud June 14, 2020 10:01PM |
