Hi to all I have an issue wen try to set home to my printer. I have upgrade to skr 1.4 with TMC2208
Maiboard BTT skr 1.4
Drivers BTT TMC2208 UART 3.0
EndStop Fisical (new and tested before and after install) (inverted mode)
Description: Sending home "G28" it stop Randomly, and I have to try Again and Again to set home (normally axises X or Z),
when dont have any error, and all Axises are in home, and start to print. (send the G28 Z0) some times does not touch the EndStop and start printing to high.
and mayor times I get the Error "Print halted"
this is a test using ProntFace.
SENT: G28
SENT: G92 E0
SENT: M114
SENT: M105
RECV: echo:busy: processing
SENT: M105
SENT: M105
RECV: Error: Printer halted. kill() called!
[ERROR] Error: Printer halted. kill() called!
>>> G28 X
SENT: G28 X
SENT: M105
when axis Z raise one busy processing and is almost to touch the endstop the possition is a little bit lower than normal.
>>> G28 Z
SENT: G28 Z
SENT: M105
RECV: X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
Edited 1 time(s). Last edit at 11/18/2020 06:58AM by enano79.
