[Marlin-bugfix-2.0.x] Compiling fail with FILAMENT_RUNOUT_SENSOR option January 01, 2021 05:17PM |
Processing STM32F103RET6_creality (platform: ststm32@~10.0; board: genericSTM32F103RE; framework: arduino) ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Verbose mode can be enabled via `-v, --verbose` option CONFIGURATION: [docs.platformio.org] PLATFORM: ST STM32 (10.0.1) > STM32F103RE (64k RAM. 512k Flash) HARDWARE: STM32F103RET6 72MHz, 64KB RAM, 512KB Flash DEBUG: Current (jlink) External (blackmagic, cmsis-dap, jlink, stlink) PACKAGES: - framework-arduinoststm32-maple 3.10000.201129 (1.0.0) - tool-stm32duino 1.0.1 - toolchain-gccarmnoneeabi 1.70201.0 (7.2.1) Converting Marlin.ino LDF: Library Dependency Finder -> [bit.ly] LDF Modes: Finder ~ chain, Compatibility ~ soft Found 28 compatible libraries Scanning dependencies... Dependency Graph |-- 1.0.0 |-- 0.4.3 | |-- 1.0 |-- 1.0 |-- |-- 0.99 |-- 1.0 |-- 1.1.2 Building in release mode Compiling .pio/build/STM32F103RET6_creality/src/src/HAL/STM32F1/HAL.cpp.o Compiling .pio/build/STM32F103RET6_creality/src/src/HAL/STM32F1/HAL_SPI.cpp.o Compiling .pio/build/STM32F103RET6_creality/src/src/HAL/STM32F1/MarlinSerial.cpp.o Compiling .pio/build/STM32F103RET6_creality/src/src/HAL/STM32F1/SPI.cpp.o In file included from Marlin/src/HAL/STM32F1/../../inc/MarlinConfig.h:49:0, from Marlin/src/HAL/STM32F1/HAL_SPI.cpp:32: Marlin/src/HAL/STM32F1/../../inc/SanityCheck.h:857:5: error: static assertion failed: ADVANCED_PAUSE_FEATURE is required to use M600 with FILAMENT_RUNOUT_SENSOR. static_assert(nullptr == strstr(FILAMENT_RUNOUT_SCRIPT, "M600"), "ADVANCED_PAUSE_FEATURE is required to use M600 with FILAMENT_RUNOUT_SENSOR."); ^~~~~~~~~~~~~ *** [.pio/build/STM32F103RET6_creality/src/src/HAL/STM32F1/HAL_SPI.cpp.o] Error 1 In file included from Marlin/src/HAL/STM32F1/../../inc/MarlinConfig.h:49:0, from Marlin/src/HAL/STM32F1/SPI.cpp:43: Marlin/src/HAL/STM32F1/../../inc/SanityCheck.h:857:5: error: static assertion failed: ADVANCED_PAUSE_FEATURE is required to use M600 with FILAMENT_RUNOUT_SENSOR. static_assert(nullptr == strstr(FILAMENT_RUNOUT_SCRIPT, "M600"), "ADVANCED_PAUSE_FEATURE is required to use M600 with FILAMENT_RUNOUT_SENSOR."); ^~~~~~~~~~~~~ In file included from Marlin/src/HAL/STM32F1/../../inc/MarlinConfig.h:49:0, from Marlin/src/HAL/STM32F1/HAL.cpp:30: Marlin/src/HAL/STM32F1/../../inc/SanityCheck.h:857:5: error: static assertion failed: ADVANCED_PAUSE_FEATURE is required to use M600 with FILAMENT_RUNOUT_SENSOR. static_assert(nullptr == strstr(FILAMENT_RUNOUT_SCRIPT, "M600"), "ADVANCED_PAUSE_FEATURE is required to use M600 with FILAMENT_RUNOUT_SENSOR."); ^~~~~~~~~~~~~ In file included from Marlin/src/HAL/STM32F1/../../inc/MarlinConfig.h:49:0, from Marlin/src/HAL/STM32F1/MarlinSerial.cpp:25: Marlin/src/HAL/STM32F1/../../inc/SanityCheck.h:857:5: error: static assertion failed: ADVANCED_PAUSE_FEATURE is required to use M600 with FILAMENT_RUNOUT_SENSOR. static_assert(nullptr == strstr(FILAMENT_RUNOUT_SCRIPT, "M600"), "ADVANCED_PAUSE_FEATURE is required to use M600 with FILAMENT_RUNOUT_SENSOR."); ^~~~~~~~~~~~~ *** [.pio/build/STM32F103RET6_creality/src/src/HAL/STM32F1/SPI.cpp.o] Error 1 *** [.pio/build/STM32F103RET6_creality/src/src/HAL/STM32F1/HAL.cpp.o] Error 1 *** [.pio/build/STM32F103RET6_creality/src/src/HAL/STM32F1/MarlinSerial.cpp.o] Error 1 ==================================================================================== [FAILED] Took 5.92 seconds ==================================================================================== Environment Status Duration ---------------------- -------- ------------ STM32F103RET6_creality FAILED 00:00:05.918 =============================================================================== 1 failed, 0 succeeded in 00:00:05.918 =============================================================================== The terminal process "pio 'run'" terminated with exit code: 1. Terminal will be reused by tasks, press any key to close it.
Re: [Marlin-bugfix-2.0.x] Compiling fail with FILAMENT_RUNOUT_SENSOR option January 01, 2021 06:50PM |
Admin Registered: 13 years ago Posts: 7,025 |
Re: [Marlin-bugfix-2.0.x] Compiling fail with FILAMENT_RUNOUT_SENSOR option January 02, 2021 06:13AM |
