Interfacing with the Wanhao i3 LCD June 03, 2020 09:07PM |
For those who struggles to connect the stock wanhao i3 1.2 LCD display. I got it working by connecting the following pins: pin 1 LCD CS –> 1.19 EXP 1 pin 2 Encoder B –> 3.25 EXP 2 pin 3 LCD Data –> 1.18 EXP 1 Pin 4 Encoder A–> 3.26 EXP 2 pin 5 LCD SCLK –> 1.20 EXP 1 pin 6 Encoder Button –> 0.28 EXP 1 pin 7 ESTOP –> I dont use that one- so did not try to find it pin 8 Beeper –> 1.30 EXP 1 Pin 9 5v –> 5V EXP 1 pin 10 GND –> GND EXP 1 LCD pins should like this: 1 2 3 4 5 6 7 8 9 10
/** * Melzi SKR * _____ _____ * GND |10 9 | 5V 5V |10 9 | GND * A4 | 8 7 | D10/RX1 1.23 | 8 7 | 1.22 * A3 | 6 5 D11/TX1 -> 1.21 | 6 5 1.20 * A2 | 4 3 | D16/SCL 1.19 | 4 3 | 1.18 * A1 | 2 1 | D17/SDA 0.28 | 2 1 | 1.30 * ----- ----- * EXP1 */
#define LCD_PINS_RS 17 #define LCD_PINS_ENABLE 16 #define LCD_PINS_D4 11 #define BOARD_ST7920_DELAY_1 DELAY_NS(0) #define BOARD_ST7920_DELAY_2 DELAY_NS(188) #define BOARD_ST7920_DELAY_3 DELAY_NS(0)
Re: Interfacing with the Wanhao i3 LCD June 03, 2020 11:26PM |
Admin Registered: 13 years ago Posts: 7,008 |
Re: Interfacing with the Wanhao i3 LCD June 04, 2020 09:13AM |
Re: Interfacing with the Wanhao i3 LCD June 04, 2020 10:39AM |
/** * _____ _____ * NC | · · | GND 5V | · · | GND * RESET | · · | 1.31(SD_DETECT) (LCD_D7) 1.23 | · · | 1.22 (LCD_D6) * (MOSI)0.18 | · · | 3.25(BTN_EN2) (LCD_D5) 1.21 | · · | 1.20 (LCD_D4) * (SD_SS)0.16 | · · | 3.26(BTN_EN1) (LCD_RS) 1.19 | · · | 1.18 (LCD_EN) * (SCK)0.15 | · · | 0.17(MISO) (BTN_ENC) 0.28 | · · | 1.30 (BEEPER) * ----- ----- * EXP2 EXP1 */
/** * _____ _____ * NC | · · | GND 5V | x x | GND * RESET | x · | 1.31(SD_DETECT) (LCD_D7) 1.23 | · · | 1.22 (LCD_D6) * (MOSI)0.18 | x x | 3.25(BTN_EN2) (LCD_D5) 1.21 | · · | 1.20 (LCD_D4) * (SD_SS)0.16 | · x | 3.26(BTN_EN1) (LCD_RS) 1.19 | · x | 1.18 (LCD_EN) * (SCK)0.15 | x · | 0.17(MISO) (BTN_ENC) 0.28 | x x | 1.30 (BEEPER) * ----- ----- * EXP2 EXP1 */
Re: Interfacing with the Wanhao i3 LCD June 04, 2020 06:32PM |
Re: Interfacing with the Wanhao i3 LCD February 10, 2021 05:35PM |
/** Melzi V4 12864 display pinout * _____ * GRN | 1 2 | 5V * Buzz | 3 4 | e-Stop * Encoder ENC-EN1 | 5 6 Display D4 * Encoder ENC | 7 8 | Display Enable * Encoder ENC-EN2 | 9 10| Display RS * ----- * EXP1 */
/** SKR 1.4 EXP1 * _____ * 5V | 1 2 | GRN * Display Enable| 3 4 | Display RS * Display D4 | 5 6 Encoder ENC * | 7 8 | Encoder ENC-EN2 * Encoder ENC-EN1 | 9 10| Buzz * ----- * EXP1 */
Display SKR 1 ------------> 2 2 ------------> 1 3 ------------> 10 4 ------------> NC (Not Connected) 5 ------------> 9 6 ------------> 5 7 ------------> 6 8 ------------> 3 9 ------------> 8 10 -----------> 4
