About heating failed system stopped heater_id 0 April 21, 2018 04:22AM |
Re: About heating failed system stopped heater_id 0 April 21, 2018 06:57AM |
Admin Registered: 13 years ago Posts: 7,007 |
Re: About heating failed system stopped heater_id 0 April 21, 2018 08:10AM |
Re: About heating failed system stopped heater_id 0 April 21, 2018 08:35AM |
/** * --NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table * * Temperature sensors available: * * -3 : thermocouple with MAX31855 (only for sensor 0) * -2 : thermocouple with MAX6675 (only for sensor 0) * -1 : thermocouple with AD595 * 0 : not used * 1 : 100k thermistor - best choice for EPCOS 100k (4.7k pullup) * 2 : 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup) * 3 : Mendel-parts thermistor (4.7k pullup) * 4 : 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !! * 5 : 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (4.7k pullup) * 6 : 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup) * 7 : 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup) * 71 : 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup) * 8 : 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) * 9 : 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup) * 10 : 100k RS thermistor 198-961 (4.7k pullup) * 11 : 100k beta 3950 1% thermistor (4.7k pullup) * 12 : 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) (calibrated for Makibox hot bed) * 13 : 100k Hisens 3950 1% up to 300°C for hotend "Simple ONE " & "Hotend "All In ONE" * 20 : the PT100 circuit found in the Ultimainboard V2.x * 60 : 100k Maker's Tool Works Kapton Bed Thermistor beta=3950 * 66 : 4.7M High Temperature thermistor from Dyze Design * 70 : the 100K thermistor found in the bq Hephestos 2 * 75 : 100k Generic Silicon Heat Pad with NTC 100K MGB18-104F39050L32 thermistor * * 1k ohm pullup tables - This is atypical, and requires changing out the 4.7k pullup for 1k. * (but gives greater accuracy and more stable PID) * 51 : 100k thermistor - EPCOS (1k pullup) * 52 : 200k thermistor - ATC Semitec 204GT-2 (1k pullup) * 55 : 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (1k pullup) * * 1047 : Pt1000 with 4k7 pullup * 1010 : Pt1000 with 1k pullup (non standard) * 147 : Pt100 with 4k7 pullup * 110 : Pt100 with 1k pullup (non standard) * * Use these for Testing or Development purposes. NEVER for production machine. * 998 : Dummy Table that ALWAYS reads 25°C or the temperature defined below. * 999 : Dummy Table that ALWAYS reads 100°C or the temperature defined below.
#define TEMP_SENSOR_0 1
Re: About heating failed system stopped heater_id 0 April 21, 2018 08:43AM |
P\V 12v 24v 25w (Blue Leads) 5.76Ω 23.04Ω 30w (Blue Leads) 4.8Ω 19.2Ω 40w (Red Leads) 3.6Ω 14.4Ω
Re: About heating failed system stopped heater_id 0 April 22, 2018 10:08PM |
Re: About heating failed system stopped heater_id 0 April 22, 2018 10:40PM |
Re: About heating failed system stopped heater_id 0 September 09, 2020 05:39AM |
Re: About heating failed system stopped heater_id 0 September 09, 2020 11:29AM |
Re: About heating failed system stopped heater_id 0 January 30, 2021 04:41AM |
Re: About heating failed system stopped heater_id 0 January 30, 2021 04:48AM |
Re: About heating failed system stopped heater_id 0 January 30, 2021 05:04AM |
Re: Re: About heating failed system stopped heater_id 0 February 11, 2021 11:36PM |
