Hello
MKS SGEN V2.0 board MKS TFT35 touch screen
Marlin-bugfix-2.0.x from [
github.com]
I hope someone can help me here. I have tried several version of the firmware found on GITHUB, MAKERBASE and BIGTREE and different MICRO-SD cards, different computer all with the same results. I use VS Code and PlatformIO and the Marlin extension to make the firmware.bin file, copy it to the SD card and boot the board with it in. The lights flash to indicate that the board is installing the firmware and it even changes the file from .bin to .CUR. After all that the first blue LED will flash 3 times then go out, flash rapidly 5 or 6 times go out and then all LED's will light, reset I assume, then the whole sequence starts all over again. What am I doing wrong?
