Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 18, 2020 10:59AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 18, 2020 08:26PM |
Admin Registered: 13 years ago Posts: 7,012 |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 19, 2020 07:33AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 19, 2020 07:30PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 19, 2020 10:23PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 20, 2020 12:19AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 20, 2020 01:34AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 20, 2020 06:42AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 20, 2020 06:47AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 20, 2020 09:30AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 20, 2020 03:09PM |
Marlin\src\lcd\HD44780\ultralcd_HD44780.cpp:71:55: warning: invalid conversion from 'int' to 't_backlightPol' [-fpermissive] LCD_CLASS lcd(LCD_I2C_ADDRESS, LCD_WIDTH, LCD_HEIGHT); ^ In file included from Marlin\src\lcd\HD44780\ultralcd_HD44780.h:67:0, from Marlin\src\lcd\HD44780\ultralcd_HD44780.cpp:34: .pio\libdeps\mega2560\LiquidCrystal/LiquidCrystal_I2C.h:65:4: note: initializing argument 3 of 'LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t, uint8_t, t_backlightPol)' LiquidCrystal_I2C (uint8_t lcd_Addr, uint8_t backlighPin, t_backlightPol pol); ^ .pio\libdeps\mega2560\LiquidCrystal/LiquidCrystal_I2C.h: In static member function 'static void MarlinUI::init_lcd()': .pio\libdeps\mega2560\LiquidCrystal/LiquidCrystal_I2C.h:185:9: error: 'int LiquidCrystal_I2C::init()' is private int init(); ^ Marlin\src\lcd\HD44780\ultralcd_HD44780.cpp:357:14: error: within this context lcd.init(); ^ At global scope: cc1plus.exe: warning: unrecognized command line option '-Wno-register' *** [.pio\build\mega2560\src\src\lcd\HD44780\ultralcd_HD44780.cpp.o] Error 1
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 20, 2020 03:28PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 20, 2020 03:39PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 20, 2020 05:38PM |
Err: MAXTEMP: Bed Printer halted Please Reset(see image #60, link above)
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 20, 2020 07:14PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 21, 2020 11:38AM |
Rotary encoder: button D31 rotary-pins: D35 & D37(simple rotary encoder, see image #55)
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 21, 2020 06:31PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 21, 2020 07:14PM |
cysign
I prepared everything well for the first start...but then the light in my room turned off and there was magical smoke - PSU was set to 110V instead of 230V....
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 21, 2020 08:10PM |
That's what Im going to be, soon (if somebody reads this, and is unexperienced: better never open a PSU!). I already ordered a replacement PSU, as well as swap the broken fuse against a fuse-holder and order spare parts to repair the broken one, later. A powerfull 12V PSU is always good to have in spareQuote
Roberts_Clif
...only qualified Electronics Technicians should open.
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 21, 2020 10:06PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 22, 2020 11:04AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 23, 2020 02:25AM |
#elif ANY(HAS_MARLINUI_HD44780, LCD_I2C_TYPE_PCF8575, LCD_I2C_TYPE_PCA8574, SR_LCD_2W_NL, LCM1602)replace with these lines
#elif ENABLED(LCD_I2C_TYPE_PCA8574) #define USES_LIQUIDCRYSTAL_I2C #elif ANY(HAS_MARLINUI_HD44780, LCD_I2C_TYPE_PCF8575, SR_LCD_2W_NL , LCM1602)
USES_LIQUIDCRYSTAL = LiquidCrystal@1.5.0Add this line after it
USES_LIQUIDCRYSTAL_I2C = marcoschwartz/[email protected]
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 23, 2020 02:34AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 23, 2020 04:57AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 24, 2020 12:18PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 24, 2020 04:40PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 24, 2020 08:10PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 25, 2020 02:30AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 25, 2020 03:06AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 25, 2020 03:22AM |
