Dual Z TMC5160 SKR1.4 Marlin 2.0 - Only One Stepper Rotating August 29, 2021 03:23PM |
X Y Z Z2 E Enabled false false false true false Set current 900 1200 1800 900 800 RMS current 893 1195 1793 893 790 MAX current 1259 1685 2528 1259 1114 Run current 26/31 31/31 31/31 26/31 23/31 Hold current 13/31 15/31 15/31 13/31 11/31 Global scaler 130/256 147/256 220/256 130/256 130/256 CS actual 13/31 15/31 15/31 0/31 11/31 PWM scale 12 14 14 9 10 vsense stealthChop true true true false true msteps 16 16 16 256 16 interp true true true false true tstep max max max 9 max PWM thresh. [mm/s] OT prewarn false false false false false triggered OTP false false false false false off time 4 4 4 9 4 blank time 24 24 24 16 24 hysteresis -end 2 2 2 -3 2 -start 1 1 1 1 1 Stallguard thrs 0 0 0 0 0 uStep count 8 8 8 9 8 DRVSTATUS X Y Z Z2 E sg_result 0 0 0 9 0 stallguard fsactive stst * olb ola s2gb s2ga otpw ot Driver registers: X 0x80:0D:40:00 Y 0x80:0F:40:00 Z 0x80:0F:40:00 Z2 0x00:00:00:09 E 0x80:0B:40:00
Re: Dual Z TMC5160 SKR1.4 Marlin 2.0 - Only One Stepper Rotating August 29, 2021 06:09PM |
Re: Dual Z TMC5160 SKR1.4 Marlin 2.0 - Only One Stepper Rotating September 19, 2021 01:05PM |
#define E1_ENABLE_PIN PA3 #define E1_STEP_PIN PD15 #define E1_DIR_PIN PA1 #ifndef E1_CS_PIN #define E1_CS_PIN PD8 #endif #define E1_SERIAL_TX_PIN PD8 #define E1_SERIAL_RX_PIN PD8
#define Z2_ENABLE_PIN PA3 #define Z2_STEP_PIN PD15 #define Z2_DIR_PIN PA1 #ifndef Z2_CS_PIN #define Z2_CS_PIN PD8 #endif #define Z2_SERIAL_TX_PIN PD8 #define Z2_SERIAL_RX_PIN PD8
Re: Dual Z TMC5160 SKR1.4 Marlin 2.0 - Only One Stepper Rotating September 20, 2021 01:24AM |
Admin Registered: 13 years ago Posts: 7,005 |
