Hello Everyone,
I have an MKS Gen L board and I want to make one of those kinetic sand tables. To avoid having a PC connected I want to "play" the files from the sd card however it is not working. If I power up the board it is not starting. I can still connect to it with pronterface and give commands or load a file. The only time autostart works is when I upload a new hex file from visual studio. That time it starts right away when the firmware write done and the board rebooted. Pressing the reset button on the board has no effect either.
This is a very "barebone" device, 2 axis, 3 steppers, 3 endstop. Almost everything is disabled in the config (no Z axis, no bed, no extruder, no screen etc.). Latest 2.x marlin from their site.
#define MENU_ADDAUTOSTART is disabled, upon connecting to the device with pronterface I'm getting the SD card OK message and I'm also able to upload files to the SD, so I guess that should be ok. The file name on the SD is auto0.g
any idea?
Edited 1 time(s). Last edit at 10/16/2021 02:22PM by daninet.
