I've been having a problem when trying to print lines closer than around 50mm from the edges of the print bed.
the symptoms are that the z axis lifts and the printer prints the line mid-air, as if the printer tries to avoid collision with bed clips and such.
I suspect that the firmware might be the problem as I configured it myself and when previewing the print in the slicer (super slicer) the lines and travels display correctly.
does anyone have any idea for what causes the problem?
the config.h and config_adv.h files are attached to the post.
Thanks in advance,
Matt.
