hi all 2 years ago i build my own 3d printer 400x400x400
i used a ramps1.4 board and marlin1.9 and it has been working fine.
but i wanted to go faster so i replaced the MEGA with a DUE (BOARD_RADDS) and trying to use marlin 2.1.1 and almost everything seems to work fine.
but i use a BLTOUCH and it works fine but i like to use AUTO_BED_LEVELING_BILINEAR but the moment i enable that (uncomment the //) and try to compile it i get
Compilation error: could not convert '5' from 'int' to 'XYval::'
and i found out the '5' is from "#define GRID_MAX_POINTS_X 5" if i change the 5 with a other value like default 3 it get
Compilation error: could not convert '3' from 'int' to 'XYval::'
Why! i dont get it. can someone shed some light on this issue?
marlinerrorcode.txt Error from IDE
configfile.txt config file for marlin
