setting up dual y axis on creality v4.2.7 November 17, 2022 01:32PM |
Re: setting up dual y axis on creality v4.2.7 November 17, 2022 06:49PM |
Admin Registered: 13 years ago Posts: 7,005 |
diff --git a/Marlin/Configuration.h b/Marlin/Configuration.h index 87a98298a5..052ece4414 100644 --- a/Marlin/Configuration.h +++ b/Marlin/Configuration.h @@ -87,7 +87,10 @@ // Choose the name from boards.h that matches your setup #ifndef MOTHERBOARD - #define MOTHERBOARD BOARD_RAMPS_14_EFB + #define MOTHERBOARD BOARD_CREALITY_V427 + #define Y2_STEP_PIN PB6 + #define Y2_DIR_PIN PB5 + #define Y2_ENABLE_PIN PC3 #endif /** @@ -98,7 +101,7 @@ * * :[-1, 0, 1, 2, 3, 4, 5, 6, 7] */ -#define SERIAL_PORT 0 +#define SERIAL_PORT 1 /** * Serial Port Baud Rate @@ -160,9 +163,9 @@ */ #define X_DRIVER_TYPE A4988 #define Y_DRIVER_TYPE A4988 -#define Z_DRIVER_TYPE A4988 +//#define Z_DRIVER_TYPE A4988 //#define X2_DRIVER_TYPE A4988 -//#define Y2_DRIVER_TYPE A4988 +#define Y2_DRIVER_TYPE A4988 //#define Z2_DRIVER_TYPE A4988 //#define Z3_DRIVER_TYPE A4988 //#define Z4_DRIVER_TYPE A4988 @@ -1036,7 +1039,7 @@ // extra connectors. Leave undefined any used for non-endstop and non-probe purposes. #define USE_XMIN_PLUG #define USE_YMIN_PLUG -#define USE_ZMIN_PLUG +//#define USE_ZMIN_PLUG //#define USE_IMIN_PLUG //#define USE_JMIN_PLUG //#define USE_KMIN_PLUG @@ -1168,16 +1171,16 @@ /** * Default Axis Steps Per Unit (linear=steps/mm, rotational=steps/°) * Override with M92 - * X, Y, Z [, I [, J [, K...]]], E0 [, E1[, E2...]] + * X, Y [, Z [, I [, J [, K...]]]], E0 [, E1[, E2...]] */ -#define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 400, 500 } +#define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 500 } /** * Default Max Feed Rate (linear=mm/s, rotational=°/s) * Override with M203 - * X, Y, Z [, I [, J [, K...]]], E0 [, E1[, E2...]] + * X, Y [, Z [, I [, J [, K...]]]], E0 [, E1[, E2...]] */ -#define DEFAULT_MAX_FEEDRATE { 300, 300, 5, 25 } +#define DEFAULT_MAX_FEEDRATE { 300, 300, 25 } //#define LIMITED_MAX_FR_EDITING // Limit edit via M203 or LCD to DEFAULT_MAX_FEEDRATE * 2 #if ENABLED(LIMITED_MAX_FR_EDITING) @@ -1188,9 +1191,9 @@ * Default Max Acceleration (speed change with time) (linear=mm/(s^2), rotational=°/(s^2)) * (Maximum start speed for accelerated moves) * Override with M201 - * X, Y, Z [, I [, J [, K...]]], E0 [, E1[, E2...]] + * X, Y [, Z [, I [, J [, K...]]]], E0 [, E1[, E2...]] */ -#define DEFAULT_MAX_ACCELERATION { 3000, 3000, 100, 10000 } +#define DEFAULT_MAX_ACCELERATION { 3000, 3000, 10000 } //#define LIMITED_MAX_ACCEL_EDITING // Limit edit via M201 or LCD to DEFAULT_MAX_ACCELERATION * 2 #if ENABLED(LIMITED_MAX_ACCEL_EDITING) @@ -1685,7 +1688,7 @@ // :[-1,1] #define X_HOME_DIR -1 #define Y_HOME_DIR -1 -#define Z_HOME_DIR -1 +//#define Z_HOME_DIR -1 //#define I_HOME_DIR -1 //#define J_HOME_DIR -1 //#define K_HOME_DIR -1 @@ -2096,7 +2099,7 @@ #endif // Homing speeds (linear=mm/min, rotational=°/min) -#define HOMING_FEEDRATE_MM_M { (50*60), (50*60), (4*60) } +#define HOMING_FEEDRATE_MM_M { (50*60), (50*60) } // Validate that endstops are triggered on homing moves #define VALIDATE_HOMING_ENDSTOPS @@ -3210,7 +3213,7 @@ // Use software PWM to drive the fan, as for the heaters. This uses a very low frequency // which is not as annoying as with the hardware PWM. On the other hand, if this frequency // is too low, you should also increment SOFT_PWM_SCALE. -//#define FAN_SOFT_PWM +#define FAN_SOFT_PWM // Incrementing this by 1 will double the software PWM frequency, // affecting heaters, and the fan if FAN_SOFT_PWM is enabled. diff --git a/Marlin/Configuration_adv.h b/Marlin/Configuration_adv.h index 9a54b10b82..090c9baad7 100644 --- a/Marlin/Configuration_adv.h +++ b/Marlin/Configuration_adv.h @@ -876,8 +876,8 @@ //#define SENSORLESS_BACKOFF_MM { 2, 2, 0 } // (linear=mm, rotational=°) Backoff from endstops before sensorless homing -#define HOMING_BUMP_MM { 5, 5, 2 } // (linear=mm, rotational=°) Backoff from endstops after first bump -#define HOMING_BUMP_DIVISOR { 2, 2, 4 } // Re-Bump Speed Divisor (Divides the Homing Feedrate) +#define HOMING_BUMP_MM { 5, 5 } // (linear=mm, rotational=°) Backoff from endstops after first bump +#define HOMING_BUMP_DIVISOR { 2, 2 } // Re-Bump Speed Divisor (Divides the Homing Feedrate) //#define HOMING_BACKOFF_POST_MM { 2, 2, 2 } // (linear=mm, rotational=°) Backoff from endstops after homing //#define XY_COUNTERPART_BACKOFF_MM 0 // (mm) Backoff X after homing Y, and vice-versa @@ -1086,7 +1086,7 @@ //#define SHAPING_MENU // Add a menu to the LCD to set shaping parameters. #endif -#define AXIS_RELATIVE_MODES { false, false, false, false } +#define AXIS_RELATIVE_MODES { false, false, false } // Add a Duplicate option for well-separated conjoined nozzles //#define MULTI_NOZZLE_DUPLICATION
Re: setting up dual y axis on creality v4.2.7 November 17, 2022 09:35PM |
Re: setting up dual y axis on creality v4.2.7 November 18, 2022 06:47AM |
Admin Registered: 16 years ago Posts: 13,890 |
Wow thanks I’ll give it a try.
Thank you for your hard work!!
Re: setting up dual y axis on creality v4.2.7 November 19, 2022 04:38PM |
Re: setting up dual y axis on creality v4.2.7 November 19, 2022 05:42PM |
Re: setting up dual y axis on creality v4.2.7 November 19, 2022 07:10PM |
Re: setting up dual y axis on creality v4.2.7 November 19, 2022 07:54PM |
Re: setting up dual y axis on creality v4.2.7 November 21, 2022 07:14AM |
Re: setting up dual y axis on creality v4.2.7 November 21, 2022 03:44PM |
Re: setting up dual y axis on creality v4.2.7 November 22, 2022 09:23AM |
Re: setting up dual y axis on creality v4.2.7 November 22, 2022 02:58PM |
Re: setting up dual y axis on creality v4.2.7 November 22, 2022 04:41PM |
Re: setting up dual y axis on creality v4.2.7 November 25, 2022 02:53PM |
Re: setting up dual y axis on creality v4.2.7 November 25, 2022 03:01PM |
