6 axis UVW do not move February 21, 2023 06:32PM |
Re: 6 axis UVW do not move February 21, 2023 08:33PM |
Re: 6 axis UVW do not move February 21, 2023 11:55PM |
Admin Registered: 13 years ago Posts: 7,007 |
Re: 6 axis UVW do not move February 22, 2023 12:04AM |
Re: 6 axis UVW do not move February 22, 2023 04:04AM |
Re: 6 axis UVW do not move February 22, 2023 04:11AM |
Thank you for replying. Indeed it's COREXY and I did not even think that UVW not working could be related to that... Is there any way to make UVW not related to X,Y and Z? Because in my case they are not parallel to anything, they are just separate actuators. I could almost get away with driving those actuators by a separate controller, but I'd prefer to drive them all by one controller. So it would be perfect, it I could just say to marlin, that they are separate things not "minor axis parallel to X" or something... Is there such a way?Quote
Dust
You seem to have COREXY, or MARKFORGED_XY, or MARKFORGED_YX or a SCARA, DELTA, since it says Count A and B and not X and Y
I believe that the additional axes only works with stock Cartesian machines.
Re: 6 axis UVW do not move February 22, 2023 04:38AM |
Or did I even assume correctly, that the problem is that because in COREXY the X and Y axis are a mix of 2 motor movements (A and B as they are called in code) there would be confusion of what are UVW parallel to - is U parallel to X or A? So I assumed, that for that reason UVW are intentionally disabled in case of COREXY. Is that correct? I could not find a place in the planner.cpp, that would disable the UWV in case of CORE machines...Quote
Dust
