PID Autotune December 29, 2023 12:38PM |
Re: PID Autotune December 29, 2023 04:05PM |
Admin Registered: 13 years ago Posts: 7,036 |
Re: PID Autotune December 29, 2023 06:09PM |
Re: PID Autotune December 29, 2023 06:22PM |
Re: PID Autotune December 29, 2023 06:28PM |
Re: PID Autotune December 29, 2023 06:58PM |
/** * Extruder cooling fans * * Extruder auto fans automatically turn on when their extruders' * temperatures go above EXTRUDER_AUTO_FAN_TEMPERATURE. * * Your board's pins file specifies the recommended pins. Override those here * or set to -1 to disable completely. * * Multiple extruders can be assigned to the same pin in which case * the fan will turn on when any selected extruder is above the threshold. */ #define E0_AUTO_FAN_PIN FAN0_PIN #define E1_AUTO_FAN_PIN -1 #define E2_AUTO_FAN_PIN -1 #define E3_AUTO_FAN_PIN -1 #define E4_AUTO_FAN_PIN -1 #define E5_AUTO_FAN_PIN -1 #define E6_AUTO_FAN_PIN -1 #define E7_AUTO_FAN_PIN -1 #define CHAMBER_AUTO_FAN_PIN -1 #define COOLER_AUTO_FAN_PIN -1 #define EXTRUDER_AUTO_FAN_TEMPERATURE 65 #define EXTRUDER_AUTO_FAN_SPEED 255 // 255 == full speed #define CHAMBER_AUTO_FAN_TEMPERATURE 30 #define CHAMBER_AUTO_FAN_SPEED 255 #define COOLER_AUTO_FAN_TEMPERATURE 18 #define COOLER_AUTO_FAN_SPEED 255
Re: PID Autotune December 29, 2023 07:30PM |
Re: PID Autotune December 29, 2023 07:44PM |
Re: PID Autotune December 29, 2023 07:53PM |
Re: PID Autotune December 29, 2023 08:36PM |
STRING_DISTRIBUTION_DATE "2023-12-30"
CONFIGURATION_H_VERSION 02010300
#define E0_AUTO_FAN_PIN FAN1_PINAnd, it says I have too many fans assigned!!
Marlin\src\HAL\STM32\../../inc/SanityCheck.h:994:4: error: #error "The selected board doesn't support enough user-controlled fans. Reduce NUM_M106_FANS."When
#define NUM_M106_FANS 1Can't really be expected to be set to zero.
Re: PID Autotune December 29, 2023 08:37PM |
Verbose mode can be enabled via `-v, --verbose` option Generating config.ini ... Copying variant MARLIN_H723VG to framework directory... CONFIGURATION: [docs.platformio.org] PLATFORM: ST STM32 (15.4.1) > STM32H723VG (564k RAM. 1024k Flash) HARDWARE: STM32H723VGT6 550MHz, 564KB RAM, 1MB Flash DEBUG: Current (cmsis-dap) External (cmsis-dap, jlink, stlink) PACKAGES: - framework-arduinoststm32 @ 4.20200.221104 (2.2.0) - framework-cmsis @ 2.50700.210515 (5.7.0) - toolchain-gccarmnoneeabi @ 1.90201.191206 (9.2.1) Converting Marlin.ino LDF: Library Dependency Finder -> [bit.ly] LDF Modes: Finder ~ chain, Compatibility ~ soft Found 16 compatible libraries Scanning dependencies... Dependency Graph |-- TMCStepper @ 0.7.3 |-- Adafruit NeoPixel @ 1.8.7 |-- U8glib-HAL @ 0.5.4 |-- SlowSoftI2CMaster @ 1.0.0 |-- SlowSoftWire @ 0.0.0+20231229182611 |-- IWatchdog @ 1.0.0 |-- SPI @ 1.0 |-- EEPROM @ 2.0.1 |-- SoftwareSerial @ 1.0 |-- Wire @ 1.0 |-- Servo @ 1.1.2 Building in release mode Compiling .pio\build\STM32H723VG_btt\src\src\HAL\STM32\HAL.cpp.o Compiling .pio\build\STM32H723VG_btt\src\src\HAL\STM32\HAL_SPI.cpp.o Compiling .pio\build\STM32H723VG_btt\src\src\HAL\STM32\HardwareSerial.cpp.o Compiling .pio\build\STM32H723VG_btt\src\src\HAL\STM32\MarlinSPI.cpp.o Compiling .pio\build\STM32H723VG_btt\src\src\HAL\STM32\MarlinSerial.cpp.o Compiling .pio\build\STM32H723VG_btt\src\src\HAL\STM32\MinSerial.cpp.o Compiling .pio\build\STM32H723VG_btt\src\src\HAL\STM32\Servo.cpp.o Compiling .pio\build\STM32H723VG_btt\src\src\HAL\STM32\eeprom_bl24cxx.cpp.o Compiling .pio\build\STM32H723VG_btt\src\src\HAL\STM32\eeprom_flash.cpp.o Compiling .pio\build\STM32H723VG_btt\src\src\HAL\STM32\eeprom_if_iic.cpp.o In file included from Marlin\src\HAL\STM32\../../inc/MarlinConfig.h:52, from Marlin\src\HAL\STM32\HAL.cpp:26: Marlin\src\HAL\STM32\../../inc/SanityCheck.h:994:4: error: #error "The selected board doesn't support enough user-controlled fans. Reduce NUM_M106_FANS." 994 | #error "The selected board doesn't support enough user-controlled fans. Reduce NUM_M106_FANS." | ^~~~~ In file included from Marlin\src\HAL\STM32\../../inc/MarlinConfig.h:52, from Marlin\src\HAL\STM32\HAL_SPI.cpp:26: Marlin\src\HAL\STM32\../../inc/SanityCheck.h:994:4: error: #error "The selected board doesn't support enough user-controlled fans. Reduce NUM_M106_FANS." 994 | #error "The selected board doesn't support enough user-controlled fans. Reduce NUM_M106_FANS." | ^~~~~ In file included from Marlin\src\HAL\STM32\../../inc/MarlinConfig.h:52, from Marlin\src\HAL\STM32\HardwareSerial.cpp:32: Marlin\src\HAL\STM32\../../inc/SanityCheck.h:994:4: error: #error "The selected board doesn't support enough user-controlled fans. Reduce NUM_M106_FANS." 994 | #error "The selected board doesn't support enough user-controlled fans. Reduce NUM_M106_FANS." | ^~~~~ In file included from Marlin\src\HAL\STM32\../../inc/MarlinConfig.h:52, from Marlin\src\HAL\STM32\Servo.cpp:26: Marlin\src\HAL\STM32\../../inc/SanityCheck.h:994:4: error: #error "The selected board doesn't support enough user-controlled fans. Reduce NUM_M106_FANS." 994 | #error "The selected board doesn't support enough user-controlled fans. Reduce NUM_M106_FANS." | ^~~~~ In file included from Marlin\src\HAL\STM32\../../inc/MarlinConfig.h:52, from Marlin\src\HAL\STM32\MarlinSerial.cpp:27: Marlin\src\HAL\STM32\../../inc/SanityCheck.h:994:4: error: #error "The selected board doesn't support enough user-controlled fans. Reduce NUM_M106_FANS." 994 | #error "The selected board doesn't support enough user-controlled fans. Reduce NUM_M106_FANS." | ^~~~~ In file included from Marlin\src\HAL\STM32\../../inc/MarlinConfig.h:52, from Marlin\src\HAL\STM32\eeprom_bl24cxx.cpp:32: Marlin\src\HAL\STM32\../../inc/SanityCheck.h:994:4: error: #error "The selected board doesn't support enough user-controlled fans. Reduce NUM_M106_FANS." 994 | #error "The selected board doesn't support enough user-controlled fans. Reduce NUM_M106_FANS." | ^~~~~ *** [.pio\build\STM32H723VG_btt\src\src\HAL\STM32\HAL.cpp.o] Error 1 In file included from Marlin\src\HAL\STM32\../../inc/MarlinConfig.h:52, from Marlin\src\HAL\STM32\eeprom_flash.cpp:26: Marlin\src\HAL\STM32\../../inc/SanityCheck.h:994:4: error: #error "The selected board doesn't support enough user-controlled fans. Reduce NUM_M106_FANS." 994 | #error "The selected board doesn't support enough user-controlled fans. Reduce NUM_M106_FANS." | ^~~~~ *** [.pio\build\STM32H723VG_btt\src\src\HAL\STM32\HAL_SPI.cpp.o] Error 1 In file included from Marlin\src\HAL\STM32\../../inc/MarlinConfig.h:52, from Marlin\src\HAL\STM32\eeprom_if_iic.cpp:32: Marlin\src\HAL\STM32\../../inc/SanityCheck.h:994:4: error: #error "The selected board doesn't support enough user-controlled fans. Reduce NUM_M106_FANS." 994 | #error "The selected board doesn't support enough user-controlled fans. Reduce NUM_M106_FANS." | ^~~~~ *** [.pio\build\STM32H723VG_btt\src\src\HAL\STM32\MarlinSerial.cpp.o] Error 1 *** [.pio\build\STM32H723VG_btt\src\src\HAL\STM32\Servo.cpp.o] Error 1 *** [.pio\build\STM32H723VG_btt\src\src\HAL\STM32\HardwareSerial.cpp.o] Error 1 *** [.pio\build\STM32H723VG_btt\src\src\HAL\STM32\eeprom_bl24cxx.cpp.o] Error 1 *** [.pio\build\STM32H723VG_btt\src\src\HAL\STM32\eeprom_flash.cpp.o] Error 1 *** [.pio\build\STM32H723VG_btt\src\src\HAL\STM32\eeprom_if_iic.cpp.o] Error 1
Re: PID Autotune December 29, 2023 08:51PM |
Re: PID Autotune December 29, 2023 08:55PM |
M303 E-1 C8 S60
Send: M303 E-1 C8 S60 Recv: //action:notification PID Autotune Recv: PID Autotune start Recv: //action:notification Heating... [...] Recv: //action:notification PID Cycles 0/8 [...] Recv: bias: 85 d: 85 min: 59.78 max: 60.23//action:notification PID Cycles 1/8 [...] Recv: bias: 74 d: 74 min: 59.78 max: 60.21//action:notification PID Cycles 2/8 [...] Recv: bias: 74 d: 74 min: 59.79 max: 60.17 Ku: 497.13 Tu: 21.44 Recv: No overshoot Recv: Kp: 99.43 Ki: 9.28 Kd: 710.44 Recv: //action:notification PID Cycles 3/8 [...] Recv: bias: 77 d: 77 min: 59.80 max: 60.16 Ku: 544.29 Tu: 20.80 Recv: No overshoot Recv: Kp: 108.86 Ki: 10.47 Kd: 754.61 Recv: //action:notification PID Cycles 4/8 [...] Recv: bias: 77 d: 77 min: 59.82 max: 60.18 Ku: 547.05 Tu: 20.63 Recv: No overshoot Recv: Kp: 109.41 Ki: 10.60 Kd: 752.52 Recv: //action:notification PID Cycles 5/8 [...] Recv: bias: 77 d: 77 min: 59.82 max: 60.15 Ku: 606.40 Tu: 20.47 Recv: No overshoot Recv: Kp: 121.28 Ki: 11.85 Kd: 827.61 Recv: //action:notification PID Cycles 6/8 [...] Recv: bias: 79 d: 79 min: 59.79 max: 60.16 Ku: 547.98 Tu: 20.64 Recv: No overshoot Recv: Kp: 109.60 Ki: 10.62 Kd: 753.95 Recv: //action:notification PID Cycles 7/8 [...] Recv: bias: 79 d: 79 min: 59.82 max: 60.15 Ku: 610.54 Tu: 19.67 Recv: No overshoot Recv: Kp: 122.11 Ki: 12.41 Kd: 800.78 Recv: //action:notification PID Cycles 8/8 Recv: PID Autotune finished! Put the last Kp, Ki and Kd constants from below into Configuration.h Recv: //action:notification PID tuning done Recv: #define DEFAULT_bedKp 122.11#define DEFAULT_bedKi 12.41#define DEFAULT_bedKd 800.78//action:notification BTT Kobra Max Ready. Recv: ok P15 B7
Re: PID Autotune December 30, 2023 01:53PM |
Control GCode Viewer Terminal Timelapse [...] Recv: T:21.35 /0.00 (3935.00) B:20.87 /0.00 (3934.44) @:0 B@:0 [...] Recv: T:21.35 /0.00 (3935.00) B:20.93 /0.00 (3934.06) @:0 B@:0 Send: M303 E-1 C8 S60 Recv: //action:notification PID Autotune Recv: PID Autotune start Recv: //action:notification Heating... Recv: T:21.35 /0.00 (3935.00) B:20.91 /0.00 (3934.19) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:20.86 /0.00 (3934.50) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:20.99 /0.00 (3933.69) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:21.34 /0.00 (3931.44) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:21.80 /0.00 (3928.50) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:22.36 /0.00 (3924.88) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:23.07 /0.00 (3920.38) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:23.71 /0.00 (3916.25) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:24.31 /0.00 (3912.44) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:25.06 /0.00 (3907.50) @:0 B@:127 Recv: T:21.33 /0.00 (3935.13) B:26.24 /0.00 (3897.06) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:26.97 /0.00 (3890.69) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:27.44 /0.00 (3886.56) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:27.89 /0.00 (3882.56) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:28.42 /0.00 (3877.88) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:28.86 /0.00 (3874.00) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:29.20 /0.00 (3871.00) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:29.20 /0.00 (3871.00) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:29.30 /0.00 (3870.13) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:29.76 /0.00 (3866.13) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:30.22 /0.00 (3861.88) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:30.58 /0.00 (3858.44) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:31.02 /0.00 (3854.19) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:31.39 /0.00 (3850.63) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:31.82 /0.00 (3846.56) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:32.24 /0.00 (3842.50) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:33.30 /0.00 (3832.31) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:33.77 /0.00 (3827.81) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:34.21 /0.00 (3823.63) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:34.57 /0.00 (3820.13) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:34.99 /0.00 (3816.13) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:35.32 /0.00 (3812.19) @:0 B@:127 Recv: T:21.36 /0.00 (3934.94) B:35.63 /0.00 (3808.44) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:35.74 /0.00 (3807.06) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:35.76 /0.00 (3806.94) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:35.97 /0.00 (3804.38) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:36.32 /0.00 (3800.19) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:36.65 /0.00 (3796.19) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:37.02 /0.00 (3791.75) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:37.31 /0.00 (3788.25) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:37.72 /0.00 (3783.38) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:38.05 /0.00 (3779.44) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:38.67 /0.00 (3772.00) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:39.38 /0.00 (3763.50) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:39.81 /0.00 (3758.31) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:40.06 /0.00 (3755.13) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:40.40 /0.00 (3750.63) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:40.71 /0.00 (3746.31) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:40.95 /0.00 (3743.13) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:40.96 /0.00 (3743.00) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:41.06 /0.00 (3741.56) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:41.40 /0.00 (3736.50) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:41.75 /0.00 (3732.25) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:42.05 /0.00 (3727.63) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:42.36 /0.00 (3723.88) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:42.68 /0.00 (3718.63) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:43.02 /0.00 (3714.88) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:43.98 /0.00 (3701.88) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:44.35 /0.00 (3696.81) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:44.66 /0.00 (3692.69) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:44.98 /0.00 (3688.31) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:45.29 /0.00 (3683.63) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:45.58 /0.00 (3679.19) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:45.59 /0.00 (3679.00) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:45.64 /0.00 (3678.25) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:46.02 /0.00 (3672.56) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:46.30 /0.00 (3668.31) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:46.60 /0.00 (3663.75) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:46.92 /0.00 (3658.75) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:47.23 /0.00 (3654.13) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:47.53 /0.00 (3649.56) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:48.39 /0.00 (3636.50) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:48.66 /0.00 (3632.38) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:49.05 /0.00 (3626.44) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:49.35 /0.00 (3621.94) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:49.67 /0.00 (3617.00) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:49.80 /0.00 (3615.00) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:49.82 /0.00 (3614.69) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:50.05 /0.00 (3611.06) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:50.39 /0.00 (3605.06) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:50.65 /0.00 (3600.56) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:50.92 /0.00 (3595.81) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:51.18 /0.00 (3591.31) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:51.47 /0.00 (3586.06) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:52.21 /0.00 (3573.19) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:52.55 /0.00 (3567.19) @:0 B@:127 Recv: T:21.38 /0.00 (3934.81) B:52.83 /0.00 (3562.13) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:53.12 /0.00 (3557.13) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:53.39 /0.00 (3552.25) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:53.47 /0.00 (3551.00) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:53.51 /0.00 (3550.19) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:53.80 /0.00 (3545.19) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:54.03 /0.00 (3541.00) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:54.35 /0.00 (3535.50) @:0 B@:127 Recv: T:21.36 /0.00 (3934.94) B:54.63 /0.00 (3530.44) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:54.94 /0.00 (3525.06) @:0 B@:127 Recv: T:21.37 /0.00 (3934.88) B:55.31 /0.00 (3518.13) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:55.89 /0.00 (3507.00) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:56.15 /0.00 (3501.88) @:0 B@:127 Recv: T:21.36 /0.00 (3934.94) B:56.43 /0.00 (3496.63) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:56.68 /0.00 (3491.81) @:0 B@:127 Recv: T:21.37 /0.00 (3934.88) B:56.92 /0.00 (3487.19) @:0 B@:127 Recv: T:21.35 /0.00 (3935.00) B:56.93 /0.00 (3487.00) @:0 B@:127 Recv: T:21.36 /0.00 (3934.94) B:57.07 /0.00 (3484.19) @:0 B@:127 Recv: T:21.37 /0.00 (3934.88) B:57.29 /0.00 (3480.00) @:0 B@:127 Recv: T:21.42 /0.00 (3934.50) B:57.60 /0.00 (3474.00) @:0 B@:127 Recv: T:21.36 /0.00 (3934.94) B:57.83 /0.00 (3469.63) @:0 B@:127 Recv: T:21.40 /0.00 (3934.69) B:58.13 /0.00 (3463.94) @:0 B@:127 Recv: T:21.40 /0.00 (3934.69) B:58.37 /0.00 (3459.38) @:0 B@:127 Recv: T:21.41 /0.00 (3934.63) B:59.10 /0.00 (3445.38) @:0 B@:127 Recv: T:21.39 /0.00 (3934.75) B:59.32 /0.00 (3441.06) @:0 B@:127 Recv: T:21.42 /0.00 (3934.56) B:59.62 /0.00 (3435.38) @:0 B@:127 Recv: T:21.44 /0.00 (3934.38) B:59.85 /0.00 (3430.94) @:0 B@:127 Recv: T:21.47 /0.00 (3934.19) B:60.12 /0.00 (3425.31) @:0 B@:0 Recv: T:21.44 /0.00 (3934.38) B:60.23 /0.00 (3423.06) @:0 B@:0 Recv: T:21.50 /0.00 (3934.00) B:60.23 /0.00 (3423.00) @:0 B@:0 Recv: T:21.49 /0.00 (3934.06) B:60.23 /0.00 (3423.00) @:0 B@:0 Recv: T:21.50 /0.00 (3934.00) B:60.23 /0.00 (3423.00) @:0 B@:0 Recv: T:21.49 /0.00 (3934.06) B:60.23 /0.00 (3423.00) @:0 B@:0 Recv: T:21.51 /0.00 (3933.94) B:60.23 /0.00 (3423.00) @:0 B@:0 Recv: T:21.61 /0.00 (3933.25) B:60.20 /0.00 (3423.69) @:0 B@:0 Recv: T:21.58 /0.00 (3933.50) B:60.05 /0.00 (3426.94) @:0 B@:0 Recv: //action:notification PID Cycles 0/8 Recv: T:21.59 /0.00 (3933.38) B:59.92 /0.00 (3429.50) @:0 B@:127 Recv: T:21.52 /0.00 (3933.88) B:59.81 /0.00 (3431.69) @:0 B@:127 Recv: T:21.58 /0.00 (3933.44) B:59.80 /0.00 (3431.81) @:0 B@:127 Recv: T:21.59 /0.00 (3933.38) B:59.90 /0.00 (3429.88) @:0 B@:127 Recv: T:21.63 /0.00 (3933.13) B:60.08 /0.00 (3426.13) @:0 B@:0 Recv: T:21.62 /0.00 (3933.19) B:60.22 /0.00 (3423.19) @:0 B@:0 Recv: T:21.70 /0.00 (3932.69) B:60.23 /0.00 (3423.00) @:0 B@:0 Recv: T:21.73 /0.00 (3932.44) B:60.23 /0.00 (3423.00) @:0 B@:0 Recv: T:21.73 /0.00 (3932.50) B:60.23 /0.00 (3423.00) @:0 B@:0 Recv: T:21.71 /0.00 (3932.63) B:60.22 /0.00 (3423.25) @:0 B@:0 Recv: T:21.73 /0.00 (3932.50) B:60.16 /0.00 (3424.94) @:0 B@:0 Recv: T:21.79 /0.00 (3932.06) B:60.01 /0.00 (3427.69) @:0 B@:0 Recv: bias: 87 d: 87 min: 59.77 max: 60.23//action:notification PID Cycles 1/8 Recv: T:21.87 /0.00 (3931.56) B:59.88 /0.00 (3430.25) @:0 B@:87 Recv: T:21.79 /0.00 (3932.06) B:59.80 /0.00 (3431.75) @:0 B@:87 Recv: T:21.77 /0.00 (3932.19) B:59.82 /0.00 (3431.50) @:0 B@:87 Recv: T:21.88 /0.00 (3931.44) B:59.90 /0.00 (3429.94) @:0 B@:87 Recv: T:21.82 /0.00 (3931.88) B:60.02 /0.00 (3427.63) @:0 B@:0 Recv: T:21.84 /0.00 (3931.75) B:60.11 /0.00 (3425.69) @:0 B@:0 Recv: T:21.89 /0.00 (3931.38) B:60.20 /0.00 (3423.69) @:0 B@:0 Recv: T:21.84 /0.00 (3931.75) B:60.20 /0.00 (3423.69) @:0 B@:0 Recv: T:21.90 /0.00 (3931.31) B:60.17 /0.00 (3424.31) @:0 B@:0 Recv: T:21.90 /0.00 (3931.31) B:60.13 /0.00 (3425.19) @:0 B@:0 Recv: bias: 78 d: 78 min: 59.79 max: 60.22//action:notification PID Cycles 2/8 Recv: T:22.02 /0.00 (3930.56) B:60.03 /0.00 (3427.31) @:0 B@:78 Recv: T:21.98 /0.00 (3930.81) B:59.92 /0.00 (3429.50) @:0 B@:78 Recv: T:21.92 /0.00 (3931.19) B:59.81 /0.00 (3431.63) @:0 B@:78 Recv: T:21.94 /0.00 (3931.06) B:59.86 /0.00 (3430.69) @:0 B@:78 Recv: T:21.99 /0.00 (3930.75) B:59.91 /0.00 (3429.81) @:0 B@:78 Recv: T:22.02 /0.00 (3930.56) B:60.01 /0.00 (3427.81) @:0 B@:0 Recv: T:22.00 /0.00 (3930.69) B:60.10 /0.00 (3425.94) @:0 B@:0 Recv: T:22.05 /0.00 (3930.31) B:60.15 /0.00 (3424.75) @:0 B@:0 Recv: T:22.04 /0.00 (3930.38) B:60.16 /0.00 (3424.56) @:0 B@:0 Recv: T:22.04 /0.00 (3930.38) B:60.10 /0.00 (3425.94) @:0 B@:0 Recv: T:22.07 /0.00 (3930.19) B:60.02 /0.00 (3427.63) @:0 B@:0 Recv: bias: 77 d: 77 min: 59.81 max: 60.17 Ku: 545.39 Tu: 20.47 Recv: No overshoot Recv: Kp: 109.08 Ki: 10.66 Kd: 744.42 Recv: //action:notification PID Cycles 3/8 Recv: T:22.04 /0.00 (3930.38) B:59.90 /0.00 (3429.88) @:0 B@:77 Recv: T:22.06 /0.00 (3930.25) B:59.83 /0.00 (3431.25) @:0 B@:77 Recv: T:22.11 /0.00 (3929.94) B:59.82 /0.00 (3431.44) @:0 B@:77 Recv: T:22.11 /0.00 (3929.94) B:59.85 /0.00 (3430.94) @:0 B@:77 Recv: T:22.13 /0.00 (3929.81) B:59.96 /0.00 (3428.81) @:0 B@:77 Recv: T:22.15 /0.00 (3929.69) B:60.05 /0.00 (3427.00) @:0 B@:0 Recv: T:22.15 /0.00 (3929.69) B:60.13 /0.00 (3425.19) @:0 B@:0 Recv: T:22.21 /0.00 (3929.25) B:60.15 /0.00 (3424.75) @:0 B@:0 Recv: T:22.17 /0.00 (3929.56) B:60.14 /0.00 (3425.06) @:0 B@:0 Recv: T:22.23 /0.00 (3929.13) B:60.06 /0.00 (3426.63) @:0 B@:0 Recv: bias: 78 d: 78 min: 59.78 max: 60.17 Ku: 510.37 Tu: 21.12 Recv: No overshoot Recv: Kp: 102.07 Ki: 9.66 Kd: 718.70 Recv: //action:notification PID Cycles 4/8 Recv: T:22.20 /0.00 (3929.31) B:59.98 /0.00 (3428.38) @:0 B@:78 Recv: T:22.24 /0.00 (3929.06) B:59.86 /0.00 (3430.75) @:0 B@:78 Recv: T:22.20 /0.00 (3929.31) B:59.85 /0.00 (3430.88) @:0 B@:78 Recv: T:22.20 /0.00 (3929.31) B:59.81 /0.00 (3431.69) @:0 B@:78 Recv: T:22.25 /0.00 (3929.00) B:59.91 /0.00 (3429.75) @:0 B@:78 Recv: T:22.30 /0.00 (3928.69) B:59.98 /0.00 (3428.38) @:0 B@:0 Recv: T:22.28 /0.00 (3928.81) B:60.10 /0.00 (3425.94) @:0 B@:0 Recv: T:22.34 /0.00 (3928.38) B:60.11 /0.00 (3425.63) @:0 B@:0 Recv: T:22.31 /0.00 (3928.63) B:60.08 /0.00 (3426.31) @:0 B@:0 Recv: T:22.40 /0.00 (3928.00) B:60.02 /0.00 (3427.50) @:0 B@:0 Recv: bias: 80 d: 80 min: 59.79 max: 60.12 Ku: 600.47 Tu: 19.51 Recv: No overshoot Recv: Kp: 120.09 Ki: 12.31 Kd: 781.17 Recv: //action:notification PID Cycles 5/8 Recv: T:22.33 /0.00 (3928.50) B:59.91 /0.00 (3429.69) @:0 B@:80 Recv: T:22.38 /0.00 (3928.13) B:59.82 /0.00 (3431.38) @:0 B@:80 Recv: T:22.39 /0.00 (3928.06) B:59.81 /0.00 (3431.56) @:0 B@:80 Recv: T:22.41 /0.00 (3927.94) B:59.87 /0.00 (3430.50) @:0 B@:80 Recv: T:22.36 /0.00 (3928.25) B:59.92 /0.00 (3429.50) @:0 B@:80 Recv: T:22.46 /0.00 (3927.63) B:60.02 /0.00 (3427.50) @:0 B@:0 Recv: T:22.41 /0.00 (3927.94) B:60.11 /0.00 (3425.69) @:0 B@:0 Recv: T:22.43 /0.00 (3927.81) B:60.14 /0.00 (3425.00) @:0 B@:0 Recv: T:22.45 /0.00 (3927.69) B:60.10 /0.00 (3425.81) @:0 B@:0 Recv: T:22.45 /0.00 (3927.69) B:60.07 /0.00 (3426.50) @:0 B@:0 Recv: bias: 82 d: 82 min: 59.80 max: 60.16 Ku: 573.88 Tu: 20.15 Recv: No overshoot Recv: Kp: 114.78 Ki: 11.39 Kd: 771.02 Recv: //action:notification PID Cycles 6/8 Recv: T:22.48 /0.00 (3927.50) B:59.99 /0.00 (3428.13) @:0 B@:82 Recv: T:22.49 /0.00 (3927.38) B:59.86 /0.00 (3430.63) @:0 B@:82 Recv: T:22.48 /0.00 (3927.44) B:59.80 /0.00 (3431.81) @:0 B@:82 Recv: T:22.56 /0.00 (3926.94) B:59.84 /0.00 (3431.13) @:0 B@:82 Recv: T:22.53 /0.00 (3927.13) B:59.91 /0.00 (3429.81) @:0 B@:82 Recv: T:22.57 /0.00 (3926.88) B:60.04 /0.00 (3427.13) @:0 B@:0 Recv: T:22.57 /0.00 (3926.88) B:60.11 /0.00 (3425.69) @:0 B@:0 Recv: T:22.62 /0.00 (3926.50) B:60.15 /0.00 (3424.69) @:0 B@:0 Recv: T:22.62 /0.00 (3926.50) B:60.16 /0.00 (3424.56) @:0 B@:0 Recv: T:22.62 /0.00 (3926.50) B:60.07 /0.00 (3426.56) @:0 B@:0 Recv: bias: 82 d: 82 min: 59.80 max: 60.17 Ku: 565.45 Tu: 20.64 Recv: No overshoot Recv: Kp: 113.09 Ki: 10.96 Kd: 777.98 Recv: //action:notification PID Cycles 7/8 Recv: T:22.64 /0.00 (3926.38) B:60.00 /0.00 (3428.00) @:0 B@:82 Recv: T:22.63 /0.00 (3926.44) B:59.86 /0.00 (3430.69) @:0 B@:82 Recv: T:22.66 /0.00 (3926.25) B:59.78 /0.00 (3432.19) @:0 B@:82 Recv: T:22.66 /0.00 (3926.25) B:59.79 /0.00 (3431.94) @:0 B@:82 Recv: T:22.65 /0.00 (3926.31) B:59.89 /0.00 (3430.06) @:0 B@:82 Recv: T:22.68 /0.00 (3926.13) B:59.98 /0.00 (3428.44) @:0 B@:82 Recv: T:22.68 /0.00 (3926.13) B:60.09 /0.00 (3426.13) @:0 B@:0 Recv: T:22.70 /0.00 (3926.00) B:60.16 /0.00 (3424.44) @:0 B@:0 Recv: T:22.72 /0.00 (3925.88) B:60.16 /0.00 (3424.31) @:0 B@:0 Recv: T:22.72 /0.00 (3925.88) B:60.12 /0.00 (3425.38) @:0 B@:0 Recv: T:22.75 /0.00 (3925.69) B:60.05 /0.00 (3427.13) @:0 B@:0 Recv: bias: 83 d: 83 min: 59.78 max: 60.19 Ku: 520.36 Tu: 21.12 Recv: No overshoot Recv: Kp: 104.07 Ki: 9.86 Kd: 732.56 Recv: //action:notification PID Cycles 8/8 Recv: PID Autotune finished! Put the last Kp, Ki and Kd constants from below into Configuration.h Recv: //action:notification PID tuning done Recv: #define DEFAULT_bedKp 104.07#define DEFAULT_bedKi 9.86#define DEFAULT_bedKd 732.56//action:notification BTT Kobra Max Ready. Recv: ok P15 B7 Recv: T:22.74 /0.00 (3925.75) B:60.00 /0.00 (3428.06) @:0 B@:83 [...] Recv: T:22.78 /0.00 (3925.44) B:59.87 /0.00 (3430.50) @:0 B@:0 [...] Recv: T:22.76 /0.00 (3925.63) B:59.75 /0.00 (3432.81) @:0 B@:0 [...] Recv: T:22.82 /0.00 (3925.19) B:59.60 /0.00 (3435.75) @:0 B@:0 [...]
SString<100> s(F(" E@:"), getHeaterPower((heater_id_t)target_extruder));To get this result:
Recv: T:23.81 /0.00 (3917.50) B:25.50 /0.00 (3903.56) E@:0 B@:0 [...] Recv: T:23.81 /0.00 (3917.50) B:25.50 /0.00 (3903.63) E@:0 B@:0 [...] Recv: T:23.80 /0.00 (3917.56) B:25.49 /0.00 (3903.69) E@:0 B@:0
TERN_(SINGLENOZZLE, if (fan < EXTRUDERS) fan = 0); // Always fan 0 for SINGLENOZZLE E fan
Re: PID Autotune December 30, 2023 02:04PM |
Re: PID Autotune December 30, 2023 06:33PM |
Re: PID Autotune December 30, 2023 07:19PM |
Dust
See Temperature::print_heater_states
s.append(" B@:", getHeaterPower(H_BED));
B@ is bed heaterpower (the raw PWM value) (note this is shifted 1 bit, right, 127 is full pwm.)
Re: PID Autotune December 30, 2023 07:22PM |
Re: PID Autotune December 30, 2023 10:33PM |
Re: PID Autotune December 31, 2023 01:39AM |
Re: PID Autotune December 31, 2023 09:06AM |
