Hello.
I mounted the bltouch on the tip of the nozzle in delta printer, so when I run M48 with Z offset of -47mm, the printer shutdown.
When configuring z-47, I changed Z_PROBE_OFFSET_RANGE_MIN in configuration.h.
Are there any other settings I should check?
-- console message --
Send: M48
Recv: M48 Z-Probe Repeatability Test
Recv: echo:busy: processing
Recv: Error
robing Failed
Changing monitoring state from "Operational" to "Error"
Send: M112
Send: N2 M112*35
Send: N3 M104 T0 S0*34
Send: N4 M104 T1 S0*36
Send: N5 M104 T2 S0*38
Send: N6 M140 S0*99
Changing monitoring state from "Error" to "Offline after error"
Connection closed, closing down monitor
