Hello! In the process to find a problem with my setup, I need some results from a working ramps+bltouch setup (please write the marlin version you are using) for the following tests:
1) send the gcode M280 P0 S10 (this extends the bltouch pin) and send M119, what's the status of the z endstop?
2) send the gcode M280 P0 S90 (it raises the bltouch pin) and send M119, what's the status of the z endstop?
3) remove the bltouch 2 wire connector from the board and send the gcode M280 P0 S10, with a multimeter measure the voltage between the two pins, what is the measure?
4) The same after sending the gcode M280 P0 S90 .
It could help me immensely, thank you in advance!!!
Voronix Core XY (custom model): Radds 1.6 (DRV8825) - Nextion 7" - E3d Titan + Hotend E3d V6 Direct - MK4DUO 4.3.3
