Hi!
I just installed Marlin 1.1.9 onto my Geeetech I3 Pro B the other day, because i was particularly curious about the manual bed leveling feature, which, as i understand it, lets me level the bed without a probe, using paper and 9 points on the bed. I've had quite the trouble leveling me bed becuase it seems to not be completely even.
So i downloaded the Marlin firmware and replaced the Configuration.h file with the one matching my Geeetech model found inside the example_configurations folder. Then i went into the Configuration.h file through the Arduino IDE, and changed my bed size as mine is a little smaller than the provided amounts and enabled MESH_BED_LEVELING and LCD_BED_LEVELING .. After uploading this to my printer i could begin the manual bed leveling which was now available through the menus. This seemed to work fine and after i was done i selected the Store settings menu option. However if I try to begin printing right after, it seems that the values created from bed leveling is not used at all, as the Z axis is not moving at all between layers when using a test print that covers the whole bed.
Is there something I'm missing?
