Hi guys!
I'm Antonio from Italy, I've an A20M Geeetech with 3DTouch sensor.
I read config.h but I'm not able to get it works!
The problem is that if I try to level the bed, the levelling is done for 2/3 of the heatbed (left side - 2/3 x assis); Ithe heatbed is 250x250mm and X0 (home) is more or less at 40mm far from left side of x assis.
Anyone can tell me what's wrong in the config.h?
Then, another question...
When the printer goes in Home, it usually do X0, Y0 and then it goes for Z0 ... but it moves to the middle of the heatbed and there it use 3DTouch for setup Z0. Well, done Home it remain in that position, but this is a problem due to the the casting of material while heating the nozzle. Any ideas about how to solve?
Last but not the least, PAUSE command! I think it's a stupid command! It just stops printing but I think it would be usefull if it lift the nozzle. How I have to setup this? in config.h? Do you think if it should be possibile to have Pause in the main menu? First row?
Thanks!!!
