I am having an issue with my X and Y axis stuttering only on accelerations and not on the constant velocity movements. I am using marlin 1.1.9 with two TMC2208 stepper drivers on the x and y-axes (the y-axis is a dual driver/motor axis). Is there a setting that I am missing somewhere? It did not do this before swapping the drivers. I am also using UART on all three of the TMC drivers if that helps out at all. Also, this effect is considerably more noticeable on higher microstepping and higher steps per mm. Thanks.
